Skid plate bolt repair - JeepForum.com
post #1 of 4 Old 04-02-2013, 12:41 PM Thread Starter
lsukevinc
1979 CJ5
When i bought my 79 CJ5 two years ago there were several issues with the jeep. Over the past 2 years I have been slowly repairing some of the previous owner's gerry rigging. My Cj had the typical broken bolts in the frame to secure the skid plate to the frame. Instead of trying to remove the bolts, he rigged up 4 pieces of all thread and steel plates bent over the frame for support.
I ordered these weld in inserts from McMaster-Carr. They will hold a 3/8" bolt. i borrowed a mag drill from work and drilled the old nuts out. Next i welded the inserts in. I need to grind the welds and do some painting.
What do you guys think?
lsukevinc is offline
post #2 of 4 Old 04-02-2013, 01:10 PM
Tigerjeep79
1979 CJ7
A definite improvement over the last repair!
Tigerjeep79 is offline
post #3 of 4 Old 04-02-2013, 01:36 PM
hp_lovecraft
1981 CJ5
Lol!! and I thought my skidplate repair was bad. I simply drilled a hole straight through the bad nutsert, through to the other side, so I could use a long bolt.
hp_lovecraft is offline
post #4 of 4 Old 04-02-2013, 02:22 PM
CSP
Very jealous of the mag drill. I hope to add one to my arsenal one of these days.
CSP is offline
cj , skid plate
