Single or 2-stage Paint. Pros and Cons? - Page 2 - JeepForum.com
post #16 of 131 Old 11-23-2011, 04:38 PM
lucdog
lucdog's Avatar
1980 CJ5
Are auto painters still using tack cloths? Or am I just old school.
Bill
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #17 of 131 Old 11-23-2011, 06:10 PM
CSP
Good call on Sherwin Williams. I always forget about them. I was thinking the closest one is Parker Rd./Yale in Aurora. They are auto paint only there, so they do have more stuff. I usually use Painter's Supply in Englewood.
CSP is offline
post #18 of 131 Old 11-23-2011, 06:36 PM Thread Starter
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
CSP,
Actually, the Parker Sherwin Williams is house paint only. I wound getting what I needed at their Denver store on 38th and I-25. Apparently auto is a separate division within Sherwin Williams, with different store locations.
Did I mention I hate driving in Denver? I should have went to Englewood in hind-sight.
One item I forgot to pick up was some face masks, dang it. I guess I'll hold my breath.
Matt
Matt1981CJ7 is online now
post #19 of 131 Old 11-23-2011, 07:25 PM
taylorjb
1973 CJ5
Keep us posted on your progress. I am in Denver and hope to be shooting paint next spring...I will probably use the products and store above if they work for you. Good luck!
JT
Denver, CO
taylorjb is offline
post #20 of 131 Old 11-24-2011, 07:19 PM Thread Starter
Matt1981CJ7
1981 CJ7
I hope you all have a belly full of Thanksgiving cheer!! Here's what I did, today:
I started out the morning by thoroughly cleaning both doors with the special cleaner. I used Q-tips around the hinges and other hard to reach places.
post #21 of 131 Old 11-24-2011, 07:23 PM Thread Starter
Matt1981CJ7
1981 CJ7
The Scotch Brite pads worked very well for scuffing the back side of the doors and other uneven surfaces.
After scuffing, I had a couple of scratches that required a little putty.
post #22 of 131 Old 11-24-2011, 07:25 PM Thread Starter
Matt1981CJ7
1981 CJ7
Next, I had to set up my paint room.
Then I sprayed the sealer.
post #23 of 131 Old 11-24-2011, 07:31 PM Thread Starter
Matt1981CJ7
1981 CJ7
Finally, I sprayed the final coats.
I ran out of light for good pictures, but I'm fairly pleased with the final finish. In hind sight, I should have thinned the final coat a little more than the recommended 4:1:1 ratio , as I ended up with a very slight orange peal texture. But I'm confident I'll be able to buff that smooth with a litlle elbow grease, tomorrow.
More to come.....
Matt
post #24 of 131 Old 11-24-2011, 08:09 PM
Area.3.Fiftyone
They turned out really nice.
I would wait a couple of days before wet sanding and buffing it out though.
Start with 1000 grit and finish with something around 2000 before buffing them out. Use a rubber backer behind the paper when wet sanding and add a couple of drops of liquid dish soap to your spray bottle to help keep the paper clean. It also makes it glide better across the new paint.
Unless you are very comfortable with a buffer, I would do them by hand. No matter what you do, stay away from the edges.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #25 of 131 Old 11-24-2011, 09:15 PM Thread Starter
Matt1981CJ7
1981 CJ7
Stan,
Thanks, your advice has been spot on.
Upon closer inspection, I need another coat along the very bottom sides.
I also have a handful of tiny flecks, that apparently spit out of my cheap spray gun, in a few places. What's the best way of knocking those off without taking too much paint underneath?
Thanks so much. again
Matt
post #26 of 131 Old 11-25-2011, 03:54 AM
gmakra
Matt next time your at the paint store pick up a Nib file they are about 10 dollars each. They will knock of the tops of NIBs with out damaging the paint. The item on the right is a run blocker and you wet sand the NIBs after with 1200 or higher then buff it out.
What PSI are you shooting at you should have a gauge on the spray gun? When the trigger is pulled you should see 23-27 PSI to shoot. Your instructions will give you the exact PSI at the gun and not at the regulator. Your regulator at the compressor could be as high as 80 PSI depending on the hose and such.
gmakra is offline
post #27 of 131 Old 11-25-2011, 04:54 AM Thread Starter
Matt1981CJ7
1981 CJ7
gmakra,
A NIB file, eh? I guess there's a tool for every job. Thanks!
My spray guns are the NAPA cheapys shown in the first post. I didn't use a regulator at the gun, just at the compressor. I shot at the 40-45 PSI (Conventional) that the paint instructions suggested.
Is low pressure usually the culprit for Nibs?
Matt
post #28 of 131 Old 11-25-2011, 06:27 AM
gmakra
Matt the pressure is critica,l in your instructions it should say what PSI you want at your air cap. That is the pressure you want at the gun with the trigger pulled. So put the regulator on the gun and pull the trigger and adjust to the recommend PSI.
HVLP is a different animal than the conventional guns make sure your spraying with the 1.4 tip and you should see some difference. The gun recomendations take precendent over the the paint specs.
gmakra is offline
post #29 of 131 Old 11-25-2011, 06:45 AM
Area.3.Fiftyone
Junk in your paint/primer is usually from a dirty gun or you didn't run it through a strainer while pouring it into the cup.
You want very low air pressure at the gun when using an HVLP type. High Volume Low Pressure. That means more material is applied @ lower pressure with greatly reduced overspray.
You could wet sand them with some 600 grit paper and shoot a coat or two more over the top if you want. That will knock down any runs or high spots and enable you to get more paint on the edges at the same time. It is common to lay 1 to 2 more coats of paint on something that you know you are going to color sand and buff. That way you can remove the orange peel and still have enough paint left by the time you are done without the risk of getting too thin.
BTW: You should always use a regulator at the gun. You can get a cheap one at Harbor Freight for about $7.00 You really never know what the pressure is at the gun if you just rely on the one at the compressor. Due to differences in air line length and diameter, you would be surprised at the drop in pressure by the time it gets to the end of the hose.
I would also recommend you install a cheap disposable water trap/filter at the gun to catch any moisture or junk from the air tank. They cost about $2.00 and are well worth it.
post #30 of 131 Old 11-25-2011, 06:50 AM
TxJeeper20
1982 CJ5
I am wanting to paint my Cj And dpont have a garage but do have a shed < can i set up some plastic hanging from the shed and coat the floor and paint it in the car port part of the shed
thats if i cant find a place to paint it in lol
Victory Loves Preparation
1982 CJ-5 350TBI/AX-15
1989 Porsche 928 S4
2003 Honda VTX 1300R
2005 Infiniti G35
TxJeeper20 is offline
Single or Double Stage Power Valve GPER Jeep CJ Forum 2 07-16-2011 05:06 PM
I got single stage enamel now, want to prep for new paint CJATE Jeep CJ Forum 1 04-12-2009 06:23 PM
t-5 pros and cons? BlueFalcon Jeep CJ Forum 9 05-14-2007 06:09 AM
Pros & Cons 76cj7renegade Jeep CJ Forum 6 01-24-2006 05:16 PM
SOA pros and cons clegger Jeep CJ Forum 0 11-13-2001 02:41 PM
