Simply wont start - JeepForum.com
post #1 of 11 Old 02-26-2011, 09:52 AM Thread Starter
jdcj5
1979 CJ5
Simply wont start
Hey y'all,
I have a 79 CJ-5. She simply will not start. The battery is fully charge, but I am not getting any power at all. The lights are not working. HELP!!!!
jdcj5 is offline
post #2 of 11 Old 02-26-2011, 11:59 AM
bdb86cj
If you have no lights or anything make SURE your battery is good. Take it somewhere to be tested or hook a charger to it. Don't rely on a jump because if its too drained it wont work. If its not your battery it could be your ignition switch. You would have to get a volt meter and test the connections to figure out where your aren't getting power.
bdb86cj is offline
post #3 of 11 Old 02-26-2011, 12:53 PM
dadgummit
1976 CJ7
There's two fusible links coming off the starter solenoid. Check those.
dadgummit is offline
post #4 of 11 Old 02-26-2011, 12:57 PM
Alby63
1982 CJ5
Also check the smaller red wire that is connected to the same terminal as the positive wire from the bat on the solenoid. That wire has a fusible link in it and that wire supplies the power to the interior harness.
'82 CJ5, glass body, 327, Holley Stealthram Pro 950 EFI, B&M Turbo350, Dana 44/30, Lockers, 3.73's, 6-1/2" lift, 35's, stainless mustang SLP exhaust
Alby63 is offline
post #5 of 11 Old 03-06-2011, 09:36 AM Thread Starter
jdcj5
1979 CJ5
Thank you for all of the your advice. I replace the fuse and bam. She started up. But as she was warming, she is dies again (which is normal) yet now I am not getting power again. She will not start again.
jdcj5 is offline
post #6 of 11 Old 03-06-2011, 09:41 AM
moto450r
Which fuse?
Is it blown again? If so, you need to find out what is making it "pop"...
moto450r is offline
post #7 of 11 Old 03-06-2011, 09:48 AM
brownbagg
1930 MK Compass
to start you need 12 volts to coil, air fuel. so something is shorting from igintion switch to battery, proberly the alternator.
brownbagg is offline
post #8 of 11 Old 03-06-2011, 11:17 AM Thread Starter
jdcj5
1979 CJ5
Dadgummit- I find the first fuse but where is the second one?
Moto- I replace 50 fuse leading starter solenoid which "pop". After I replaced and it started up again, it is does not "pop".
Brown- i thought is might be the alternator. I wish I could tested it, but you need the motor running to do that right? I was thinking about replacing anyways, but I have never done that before. If I did, what should I go with?
Someone told me is might be my ignition switch. But it is start up again for a little bit.
Thanks
John
jdcj5 is offline
post #9 of 11 Old 03-06-2011, 11:47 AM
robdoggydog1
1970 CJ5
a common place for it to short out if someone has messed with the wiring is through the fire wall. people just run a line through not protected and over time it wears the wire down, look closely i bet you will find it! something is grounding out that shouldnt be. good luck!
robdoggydog1 is offline
post #10 of 11 Old 03-06-2011, 11:49 AM
mlhcj7777
check your ground that will give you problems
mlhcj7777 is offline
post #11 of 11 Old 03-06-2011, 03:38 PM Thread Starter
jdcj5
1979 CJ5
Ok, I have check all the ground and they are good.
jdcj5 is offline
cj-5 , start problems
cj wont start weaver01 Jeep CJ Forum 11 05-17-2010 07:12 PM
Wont start when it's hot outside Hank86 Jeep CJ Forum 4 08-07-2009 04:50 PM
75 CJ5 wont start???? Guuby Jeep CJ Forum 8 03-21-2008 10:21 PM
Waggy D44 front simply question Blthomas Jeep CJ Forum 4 01-17-2007 11:08 AM
CJ7 wont start...what gives Quackerbox Jeep CJ Forum 8 09-03-2005 06:27 PM
