Simple headlight wiring! - JeepForum.com
post #1 of 13 Old 09-24-2011, 05:03 PM Thread Starter
budgetCJ7
1979 CJ7
So i've gotten rid of all my wiring on my jeep and started over with no harness, no fuse box, just simple!!! Now to the headlights....I'm wanting to put them on a simple on/off fused switch. Do I need relays? (don't fully understand what they do) I have factory enclosed bulbs with 3 connections on rear. Can anyone identify what connections are what? ie. power, nuetral.
And for the arguement upgrades for the bulb? Knowing my setup with simple switch can i upgrade to H4?
budgetCJ7 is offline
post #2 of 13 Old 09-24-2011, 05:12 PM
Pathkiller
1974 CJ5
The terms "no fuse box" and "don't really understand what they do" don't instill a lot of confidence in your electrical abilities. What is protecting your Jeep from turning into a flaming pyre if you don't have a fuse box?
The three connectors are for high beam, low beam and ground.
Pathkiller is offline
post #3 of 13 Old 09-24-2011, 05:25 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Simple means, start with the fuse box. Simply is the safest way to go.
Use Relays to get all the power to the headlights. You loose power just in the length of wire to the headlights. Relays allows that path to be the shortest.
John Strenk is offline
post #4 of 13 Old 09-24-2011, 05:26 PM
danturner266
1983 CJ7
I don't know if I would dare running H4's through the headlight switch. Like Pathkiller said, what's up with "no fuse box"???
1983 CJ7 350
1992 XJ Laredo - RIP
2008 WK Laredo - Mrs DD
danturner266 is offline
post #5 of 13 Old 09-24-2011, 05:34 PM Thread Starter
budgetCJ7
1979 CJ7
Not to worry. Lots of wiring experience just not automotive. I used inline fuses and the main switch panel has isolated fuses for each switch. Its a woods/mudd jeep so i've just tried to remove an unnessesary wiring, which is why i decided to start wiring from scratch.
This is how i have it setup up ..just FYI:
post #6 of 13 Old 09-24-2011, 05:36 PM Thread Starter
budgetCJ7
1979 CJ7
Wow i got some of ya'll worried about this one. Maybe i shouldn't have said 'no fuse box'. I was just trying to give you idea that I have completely sarted over with no wiring harness
post #7 of 13 Old 09-24-2011, 05:46 PM
John Strenk
1976 CJ5
We just don't you to set your jeep on fire. that's all.
If you run Relays, you can just about run any type of headlight you want without hurting switch.
Are you going to try to make it streetable also?
post #8 of 13 Old 09-24-2011, 05:49 PM
brownbagg
1930 MK Compass
a relay is a switch on a switch, it so you can run a short heavy wire from battery to relay to lights, about two foot, and then you turn the relay on with a smaller wire that goes to your dash. It so you dont have to have a large wire from battery to dash to lights, and have a huge current drop.
brownbagg is offline
post #9 of 13 Old 09-24-2011, 06:25 PM Thread Starter
budgetCJ7
1979 CJ7
Ahh now it makes sense!!!! Thank you sooo much!!!
Strenk- Thank you also! Yes at some point I'm hoping to have it street legal again. Nothing serious, just for the 30 mph drives to gym or store to show her off!!!!! Why do u ask?!
post #10 of 13 Old 09-25-2011, 07:00 PM
John Strenk
1976 CJ5
Just that if it's just going to be used off road you can make just the basics circuits but if you are driving it on the road, you might want to wire it back the way it was originally.
post #11 of 13 Old 09-25-2011, 07:26 PM
85LaredoCJ7
Anybody have jeephammer's diagram for wiring up the H4s?
85LaredoCJ7 is offline
post #12 of 13 Old 09-26-2011, 06:14 AM
Pathkiller
1974 CJ5
Because to be legal on the road you'll need a dimmer switch.
post #13 of 13 Old 09-26-2011, 06:33 AM
twoleos617
http://www.jeepforum.com/forum/f8/he...59/index3.html
i wired mine like the last diagram in post 33. works like a champ! lights are bright as can be.
also, recently replaced the $6 dimmer floor switch. it made a difference too!
Torque is the measure of force that gets the cap off your beer.
Mike D.
twoleos617 is offline
Headlight Switch Wiring racerx8413 Jeep CJ Forum 101 05-02-2016 12:06 PM
Headlight wiring kit? Jimmbo Jeep CJ Forum 4 01-17-2011 04:47 PM
headlight wiring help flyin8s234 Jeep CJ Forum 5 03-03-2010 05:50 AM
Headlight wiring-one is brighter than the other! ricewt Jeep CJ Forum 14 02-04-2010 07:20 AM
Simple headlight/wiper/heater switch question supraman1990 Jeep CJ Forum 1 11-19-2007 01:40 PM
