Simple Brake Light Upgrade - JeepForum.com
post #1 of 44 Old 04-29-2010, 02:37 PM Thread Starter
Coiz
1979 CJ7
I was tossing around the idea of trying to add LED's inside my tail lights to brighten them up a bit and keep the stock CJ look. The stock looking LED lights available are a little pricey so I figured I might as well try a cheaper solution. I figured I would share my results with all of you. So rather than buying LED lights to fit inside my stock CJ brake light housings or buying the full LED replacements, I decided to do a little test with a couple brands of reflective tape.
Here is a picture of the inside of my tail lights. The metal backing plates are a little rusty but I cleaned them up a bit with some sand paper. Notice the extra green wire with the bolt attaching it to the backing plate, that will be my dedicated ground to the lights once they are mounted on the Jeep. I also taped off the license plate opening to keep the lighting as consistent as possible.
Here are the lights with the brake light portion of the bulb illuminated. Notice that the left side is just a little bit brighter so I will keep that as my base lighting and make my modifications to the right side for comparison. You can also see a small sample of the two types of reflective tape I used.
In this picture I used that high temperature foil tape you use on interior home heating duct work. It is fairly reflective and you can see how much brighter the light is with the reflective tape installed. This is fairly similar to aluminum foil.
In this photo I lined the inside of the housing with white reflective tape that you would use on car trailers or to mark your mailbox, ect.,. This particular brand was Avery. You can see how the reflective tape outshines the aluminum tape. Pretty much what I expected to see.
Here is a picture of the reverse lights. Not quite as drastic of a difference as the brake light but brighter none-the-less.
The strips of reflective tape cost me $4.50 for a 2" x 144" worth shipped to my door off of eBay by a seller named graystone101. They are basically scrap pieces to him. It took less than half the tape to line the insides of both fixtures. Not a bad $2.50 upgrade to give my lights a little extra oomph!
Here's one with the flash.
This final picture is with the lens covers installed, stock on the left, reflective tape on the right with the brake light bulbs illuminated.
What do you think?
Mike
Coiz is offline
post #2 of 44 Old 04-29-2010, 02:49 PM
jeepsarecool
jeepsarecool's Avatar
1982 CJ7
Great idea! Why didn't I think of that?
Check out my
CJ7 - God's gift to the masochist.
jeepsarecool is offline
post #3 of 44 Old 04-29-2010, 02:53 PM
turbogus
1978 CJ5
Far out! What a great idea! ....you get a cookie
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
post #4 of 44 Old 04-29-2010, 03:57 PM
kickingprop
Thats a great idea! And a cheap no-brainer upgrade for those of us not wanting to shell out the $$ for LED's... Does that white tape have a specific trade name I should google?
1985 CJ7 Project
Phase One : 5.3L Vortec/4L60E, Moser axles for AMC20, Twin Stick'd Dana300 - Completed
Phase Two: Bedliner, Rollcage, Seats, BESRK Rear Bumper w/ tire swing, Soft Top, and a few other goodies - Mostly Complete
Phase Three: Waggy 44 front, Scout D44 Rear, 4.56's, ARB's (F/R) SOA with YJ Springs, 35x12.50x15 BFG MT - Not Even Close to beginning
Also a mostly rust-free 1970 Scout 800A That I'll get to start working on someday...
Chrome won't get you home...BUT Rattle Can Black may just get you back"
kickingprop is offline
post #5 of 44 Old 04-29-2010, 05:01 PM Thread Starter
Coiz
1979 CJ7
I edited my post with that info but the brand I ended up with was Avery. I got 8 strips 2"x18" long for $4.50 shipped to my door off of eBay by a seller named graystone101. I think any white reflective tape would work well. There are a lot of different brands. The 2" wide was perfect.
Thanks for the "Thumbs Up's" guys, I'm now up to 10.
Mike
Coiz is offline
post #6 of 44 Old 04-29-2010, 05:05 PM
Pog
Pog's Avatar
Great idea. My other hobby outside of blowing money on my CJ is blowing money on my aquarium. One of the oldest tricks in the book to increasing light in an aquarium is a simple reflector in your light strip. A reflector can effectively increase your light output by as much as 50% with no extra power consumption. Your tests are living proof.
Pog is offline
post #7 of 44 Old 04-30-2010, 03:09 AM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
im the same way, sucks having expensive hobbies...
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #8 of 44 Old 04-30-2010, 10:54 AM
turbogus
1978 CJ5
I've checked with Reflectix in with regard to their easily locally available product FT210 (a lower end tape) and they tell me it's safe to 260 degrees. There are some concerns posted by others from other sites that they're concerned with temperatures within the tail light housing. As for me, I run lights on during darkness and temperatures are cooler here in Oregon so potential danger may well be minimalized. Not to mention the brake and backup lights are used only momentarily. Going to find out what temperature they burn at.
turbogus is offline
post #9 of 44 Old 04-30-2010, 12:06 PM
turbogus
1978 CJ5
Still trying, bought an oven thermometer going to check later
turbogus is offline
post #10 of 44 Old 04-30-2010, 12:10 PM
JonB-CJ7
Thats a heck of an idea....thanks.
Jon B
1984 CJ-7, Howell fuel injection, D-44 front 4:11 Detroit Electrac,D-44 rear Detroit 4:11, T-19 trans, D-300/4:1 Lo-max gears, 33x12.5 SSRs, Full cage, Warn XDi 9000
2006 Jeep Rubicon (stock, but not for long)
JonB-CJ7 is offline
post #11 of 44 Old 04-30-2010, 12:42 PM
VACJ7
VACJ7's Avatar
You sir are a genius!
VACJ7 is offline
post #12 of 44 Old 04-30-2010, 04:02 PM Thread Starter
Coiz
1979 CJ7
Sharing my idea on other sites? I've wondered why some of my photobucket bandwidth is used on "unknown" sites. I guess that is from people direct linking to my photos, not that I care or that it matters.
I also thought about that but I believe heat is a non-issue. I just had the brake and tail light filaments powered for 10 minutes straight with the cover on the brake light housing and quickly removed it to check the temperatures with my thermal gun. The bulb, or the filament inside of it, gets to about 350-400 degrees but the tape behind it was only around 125 degrees at the hottest point and was only luke warm to the touch, nowhere near being "hot". If the tape was only 125 degrees after 10 minutes I don't think it would ever get hot enough to melt it. I have just the tail light going now and will update with what I find after 30 minutes. I'd be curious to know your results.
Mike
Coiz is offline
post #13 of 44 Old 04-30-2010, 11:51 PM Thread Starter
Coiz
1979 CJ7
So I just just tested this again and found that the outside lens temp was about 215 degrees after 35 minutes with both the tail and brake filaments illuminated. After 45 minutes it was 220 degrees. I removed the lens cover and quickly measured the temps. The bulb filament measured close to 500 degrees but all of the tape around it was maxed around 145 degrees. I could easily touch it with my fingers and it was not hot enough to make me pull away.
Mike
Coiz is offline
post #14 of 44 Old 05-01-2010, 09:27 AM
turbogus
1978 CJ5
Okay, I ran lights on for over an hour (steady state) and the maximum temperature inside the tail lights with the lens on and sealed gets no higher than 150 degrees. Since this Reflectix tape is rated to 260 I think this'll work out fine. I picked this tape up at the local hardware store, and called the maker for its temp ratings.
turbogus is offline
post #15 of 44 Old 05-02-2010, 12:22 PM
Dborns
Great idea! I would have thought that local hardware stores would have had this stuff, but nothing at HD, Lowes, or Ace. I ended up searching for graystone101 and didn't find him on ebay, but a search of "Avery" came up with the tape. Thanks!!
Dborns is offline
Simple Brake switch question DUX4LIFE Jeep CJ Forum 3 04-02-2010 05:10 PM
Simple, easy, and cheap extended brake hoses found No_Bs Jeep CJ Forum 1 11-15-2009 05:37 PM
Have a simple fuel and brake line question supraman1990 Jeep CJ Forum 7 08-17-2007 06:25 AM
Yj Brake Upgrade and Brake Lights brettv Jeep CJ Forum 10 09-25-2006 03:25 PM
Brake light on dash on after new ss brake lines Jeep Daddy Jeep CJ Forum 5 09-10-2002 06:39 PM
