Shutter - JeepForum.com
post #1 of 3 Old 03-03-2002, 06:13 PM Thread Starter
texjeep
Question Shutter
Just bought an 86 CJ7 with 6 cyl and T5. When taking off from a stop the jeep shakes and shutters when letting out the clutch.
Any ideas on a cause and a fix? Thanks for any help.
Liberty Limited Edition and
86 CJ7,I6, 5 speed
texjeep is offline
post #2 of 3 Old 03-05-2002, 12:13 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Post
bad cluch, bad engine mounts, bad trans mounts, bad body mounts.Chances are the cluch is bad. If you change it remember to turn the flywheel.
bazinga
jeepdaddy2000 is online now
post #3 of 3 Old 03-05-2002, 08:57 AM
OfFtHeWaLl
Cool
Well I had the same prob with my 84 Cj it would shudder on take off... I made the mistake of buying a new trans $2000.00 DO NOT DO THAT I found out that after I changed my spark plugs and cleaned all my grounds aloso adding two new ones, changed all my vaccume lines it stopped!!!! If your current dosent have good groung you dont get the best spark!!! Trust me try the little things first.. If you engine is dirty like mine was after I bought it clean it up and do some big maintnence... Dont buy crap till you do thoes things I said or youll kick yourself in the *** later... Hope that helps..
Thomas Mintz
84 CJ7
in 4cy
33 2in lift
it's my problem child
butt i love it
OfFtHeWaLl is offline
