Should I remove body lift? Opinions? - JeepForum.com
post #1 of 21 Old 01-18-2010, 04:14 PM Thread Starter
Jeremy_C
1978 CJ7
Trying to decide if i should remove the body lift on my jeep. Has 4inch pro comp suspension lift, 33x12.15 tires. Will eventually have 10inch wheels or so in the future.
Just trying to make it look better, and i'm not really a big fan of body lifts.
I think it sits kinda high myself, but looking for opinions from the experts.
1978 Cj7 360, Yellow.
Yellow Jeep Club member # 1982
Tennessee Vol Jeep Club # 1
Jeremy_C is offline
post #2 of 21 Old 01-18-2010, 04:18 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
I would remove it
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #3 of 21 Old 01-18-2010, 04:23 PM
rishar1
1973 CJ5
Yup remove it its too high for the wheels you got on it.
1973 CJ5
1970 Chevelle SS
1974 Bronco
rishar1 is offline
post #4 of 21 Old 01-18-2010, 04:38 PM
MoC
Well I will disagree and say it looks good the way it is and I would leave it if the body lift was only 1 inch. The one inch does not look bad at all and makes it a whole lot easier to clean mud out from between the frame and body.
MoC is offline
post #5 of 21 Old 01-18-2010, 04:58 PM Thread Starter
Jeremy_C
1978 CJ7
It looks bigger then a 1 inch body lift, i haven't measured it but it looks to be about 2 or 3 inch.
Jeremy_C is offline
post #6 of 21 Old 01-18-2010, 06:04 PM
jeepwhore
Looking at that picture that shows the back end, it only looks like an inch.....unless that rear bumper was mounted so that the top of it sits higher than the top of the rear cross member. Get a closer pic of the back from straight on and it'll be easy to tell.
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline
post #7 of 21 Old 01-18-2010, 06:17 PM
MoC
If it is a one inch body lift the spacers will be 1 inch larger than the orgnal body bushings, some where around 1 1/4 to 1 1/2 inches each. It looks like a 1 inch body lift to me as well. Again I would leave it for the ease of cleaning. Also depending on the condition of the bolts / age of the lift the bolts might be hard to get out. On my 86 I had one that I had to cut into the tub to remove. Some guys here have had 3 - 4 they have had to cut out.
MoC is offline
post #8 of 21 Old 01-18-2010, 06:52 PM
PERK
here's mine, 2" body lift, 4.5 re lift 33" tires. wouldn't change it. ride good flexes well, I think it helps that I have a scout 44 in the rear. I lengthened the steering shaft and clutch rod, so no issues there
PERK is offline
post #9 of 21 Old 01-18-2010, 06:57 PM Thread Starter
Jeremy_C
1978 CJ7
I think if i could get wider wheels, which i plan on getting at some point. 8inches now, will upgrade to 10's, i think that will help the stance alittle bit.
The body lift hasn't been on long, i think i can get to all the bolts.....looks like i will have to drop the fuel tank to get to the rear bolts.
Jeremy_C is offline
post #10 of 21 Old 01-18-2010, 07:06 PM
BriansCJ
1994 XJ Cherokee
I think the body stance looks good, you just need your tires to stick out more.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #11 of 21 Old 01-18-2010, 09:11 PM
PERK
your better off with 8" rims. get some 1 1/4" wheel spacers for a wider stance.
PERK is offline
post #12 of 21 Old 01-19-2010, 02:18 AM Thread Starter
Jeremy_C
1978 CJ7
Anybody have pictures of that setup? Kind of a specific thing to search for....
Jeremy_C is offline
post #13 of 21 Old 01-19-2010, 07:51 AM
Mike Romain
Well, if that has/had a body lift on it, you are in trouble from rust and collapsed tub mount points by the looks of the back.
The back is already down almost to the bumper and it doesn't look like an even crack so it may have sagged bad.
Mike
Mike Romain is offline
post #14 of 21 Old 01-19-2010, 08:29 AM
southshore30
1982 CJ7
the front looks like it is only up on a 1" BL. Hard to tell with the back, maybe your bumper is mounted higher up than the crossmember so one can not see the BL. Hopefully it is just the picture angle making your body look sagged down on the bumper. Maybe the bumper is the one that is not level. I would leave it if it is only a 1" lift
southshore30 is offline
post #15 of 21 Old 01-19-2010, 08:30 AM Thread Starter
Jeremy_C
1978 CJ7
That isn't level ground, i think its the way the bumper is mounted why it sits so close to the tub. No major rust issues underneath.
Jeremy_C is offline
Body Tub questions/opinions IHPuller450 Jeep CJ Forum 12 01-13-2010 10:59 AM
Cant Remove Body Mount Bolts Cowtown76CJ5 Jeep CJ Forum 4 07-19-2009 11:41 PM
Should i remove the Po's 3" body lift?? Elkaholic Jeep CJ Forum 10 03-27-2009 02:28 PM
Opinions on body high51977 Jeep CJ Forum 13 02-28-2008 05:13 PM
Replacement Body Opinions oldcatcher Jeep CJ Forum 16 08-20-2002 07:32 PM
