Should I prime before Herc or U-Pol ?? - JeepForum.com
post #1 of 9 Old 09-12-2009, 08:25 PM Thread Starter
NWA_CJ7
1983 CJ7
Had my tub sandblasted and was wondering if I should spray down some self etch before I do the inside with herc or upol?? Will probably be U-pol most likely.
83 CJ7 AMC 360, nuttered & team rushed. Dana 44 rear geared & locked, Dana 30 front geared & locked Dana 300 T. Case 4" Tough Country Lift, 1" daystar body lift, 1/2" shackle 35x12.50x15 MT MTZ's on MT classic 2's, Besrk Bumpers, Genright Tube Fenders
NWA_CJ7 is offline
post #2 of 9 Old 09-12-2009, 08:47 PM
Pricecheck
Hey man. I just u-pol'd my cj. It turned out awesome. Just took it out today and tomorrow I'm gonna powerwash the inside. Should have no problem at all.
With as small as the cj5 tub is, I was able to get 4 coats out of the kit along with heavy application to the front floors, tranny area, rear floor (in front of seat).
check out me on cardomain http://www.cardomain.com/ride/3090904
Pricecheck is offline
post #3 of 9 Old 09-12-2009, 08:49 PM
Pricecheck
Forgot to mention... I did not prime first.
post #4 of 9 Old 09-12-2009, 08:51 PM
Jeep89JV
Wouldnt suggest primer although lots of people use some spray adhesive to help the wished liner to hold on better, also can use very rough sand paper on the entire area you're covering to make a rough surface.
Lets see pics after
If you don't stand behind our troops, feel free to stand in front of them.
My Build Thread:
New Mexico Driving Rules...
  • As a general rule, the vehicle most in need of a significant amount of bodywork (for which the driver is most likely uninsured) always has the right of way.
  • Never use directional signals when changing lanes. They only serve to give away your next move, causing most NM drivers to speed up and not let you in. In fact, use of directional signals within most large NM city limits is actual illegal.
  • NM law states that at least 50% of all paved surfaces within the state must be under construction at any one time. In all construction zones, at least half of the available lanes must be closed, regardless of whether any actual construction is be accomplished or not. Construction signs shall be regularly repositioned in order to warn drivers about upcoming lane closures immediately after they pass the last exit before traffic backups.
  • Driving through constructions zones with upcoming lane closures is a popular game in NM. Itís called the "speed up and pass as many cars as you can, then see how close to the lane closure you can squeeze back into traffic before hitting any of the orange construction barrels" game.
Jeep89JV is offline
post #5 of 9 Old 09-12-2009, 10:34 PM
Coiz
1979 CJ7
It states right in the U-Pol instructions "For best results bare metal should be treated with a suitable etch primer e.g.U-Pol Acid#8 (UP07776/ UP0741)"
Mike
Coiz is offline
post #6 of 9 Old 09-13-2009, 08:21 PM Thread Starter
NWA_CJ7
1983 CJ7
Thanks for the insight. I might know that if I already had it. Do you have to use their brand or do you think any etch primer would work?
NWA_CJ7 is offline
post #7 of 9 Old 09-13-2009, 08:27 PM
Coiz
1979 CJ7
I would think any etching primer would be fine.
Mike
Coiz is offline
post #8 of 9 Old 09-14-2009, 03:04 PM
47redwillys
1967 CJ5
The auto aprts stores and the automotive paint supply stores have a product by SEM I think that works pretty well as far as primers go, but I have not used it under Raptor. I did spray my tub with Raptor after scuffing up the old paint with Scotch-brite and soap and water wash. Went on super, but it is only a month old right now.
47redwillys is offline
post #9 of 9 Old 09-14-2009, 05:45 PM
chainz
1976 CJ5
I herculined the inside of my bronco 2 and all I did was scuff it up with sand paper and hose it off. 2 years later I have no problems or complaints.
chainz is offline
New Tank and Sender - Prime the pump? Woolys_CJ7 Jeep CJ Forum 6 06-21-2009 05:18 PM
Forgot to prime new oil pump + question CrazyHorse6 Jeep CJ Forum 12 03-16-2009 04:54 PM
AMC 360 Oil Prime CJ Runner Jeep CJ Forum 16 02-23-2009 10:16 AM
I have to prime my carb everytime I start Burnswhenipe Jeep CJ Forum 6 11-05-2008 07:12 AM
prime fuel pump phil77 Jeep CJ Forum 1 04-25-2007 02:13 PM
