Should I be able to see coolant moving? - Page 4 - JeepForum.com
post #46 of 53 Old 05-10-2013, 05:03 PM Thread Starter
Turtle71
1983 CJ7
Originally Posted by hp_lovecraft View Post
The same situation with my Jeep when I first got it. The fuel gauge did not work, and the temp gauge would peg "hot" after a couple minutes of running.
So, I replaced the water pump, thermostat, and flushed the rad a couple times. Still showed it was overheating, so I starting thinking of a cracked block? or some major mechanical problem....
It was about that time I discovered this website, and noticed the John Strenk website for CJ gauges. On a whim, I tested the temp sender, and it showed it was NOT overheating. Doh! Replaced the fuel and temp gauge, and whamo.... working fuel gauge, and temp gauge showing correct temp.
Wow! Exactly my situation with the gauges, but glad I didnt give up with the testing. What brand gauges did you use?
My 83 CJ7 Build:
Turtle71 is offline
post #47 of 53 Old 05-10-2013, 06:21 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Again, guys, spit out 40 bucks for an IR gun. You can eliminate all the testing by simply finding your what the temp of the water is. they are also handy for exhaust, drivetrain, and even kitchen stove temps.
jeepdaddy2000 is offline
post #48 of 53 Old 05-10-2013, 06:24 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Or use a meat thermometer.
Matt
Matt1981CJ7 is offline
post #49 of 53 Old 05-11-2013, 08:10 PM Thread Starter
Turtle71
1983 CJ7
Ok, Just to be sure, I went and got an IR gun. Any specific area better than others to point it at to get a reading. Engine block? I know you said the temp of the water, but was hoping to get readings before it actually gets to the radiator.
My 83 CJ7 Build:
Turtle71 is offline
post #50 of 53 Old 05-11-2013, 11:25 PM
jeepdaddy2000
1971 CJ5
The t stat housing is the best. You can also check the heater output pipe, water pump, bypass hose, or even the side of the waterjacket.
post #51 of 53 Old 05-12-2013, 05:45 PM Thread Starter
Turtle71
1983 CJ7
Ran the motor at idle for at least 10 minutes. Took several measurements with the IR gun from different areas and all checked out good. Thermostat kicked in and kept temps in check. Temp gauge was pegged past the H the whole time.
My 83 CJ7 Build:
Turtle71 is offline
post #52 of 53 Old 05-12-2013, 05:50 PM Thread Starter
Turtle71
1983 CJ7
Originally Posted by SLO_Ken View Post
I've got the Crown fuel and temp gauges in mine. The temp gauge seems to work just fine. The fuel gauge required some adjustment to read correctly. Those adjustments can be found here
No that I know whats going on, I think I might pick up a set of these. How was the install???
My 83 CJ7 Build:
Turtle71 is offline
post #53 of 53 Old 05-12-2013, 06:13 PM
Gigemags05
1980 CJ7
I had this problem after I did my 4.0 swap.
I went through two thermostats, bought an ir gun, and three temp senders. So I figured it was the gauge. When I bought te new gauge it came with a temp sender that was specific to that particular gauge. Swapped it out with the sender in the jeep and haven't had any problems since.
My gauges are aftermarket that were put in by the PO.
Gigemags05 is offline
