Should 85 Jeep CJ 7 have a coolant overflow? - JeepForum.com
post #1 of 19 Old 01-02-2010, 10:41 AM Thread Starter
macg1777
I recently purchased this CJ 7 with straight 6 and was wondering if this should have a coolant overflow reservoir as I do not see one under the hood. Thanks
macg1777 is offline
post #2 of 19 Old 01-02-2010, 11:06 AM
John Strenk
John Strenk's Avatar
1976 CJ5
yes it should and it should be on the rear of the driver side fender. Next to the washer fluid bottle
John Strenk is offline
post #3 of 19 Old 01-02-2010, 11:40 AM Thread Starter
macg1777
Thanks... I guess that is something else that I need to do.
macg1777 is offline
post #4 of 19 Old 01-02-2010, 01:13 PM
wellmax
mine had one but leaked so i took it off and just run hose down side of radiator as old machines did years ago, seams to work ok. But I check fluid often, at least twice a year and add as necessary, am sure if i had a recovery tank I would never have to add any fluid.
While working on radiator i would install a new 14psi cap, having a radiator cap in good working order makes a difference as a weak cap will let fluid out when pressure builds up.
wellmax is offline
post #5 of 19 Old 01-02-2010, 01:20 PM
keith460
Jeep. There's Only One
keith460's Avatar
My 84' with a 258 didn't come with one from the factory, only had a drain hose that ran down along the side of the radiator and emptied onto the driveway for all your household pets to lap up. I'll be adding one when the body gets back onto the frame though.
1984 CJ-7 Renegade
keith460 is offline
post #6 of 19 Old 01-02-2010, 02:35 PM
wellmax
keith,
got me to thinking maybe my 84 did not have a coolant expansion tank, I knew I took off the windshield washer tank because it leaked. That maybe that was the tank I was thinking about.
So I went to the barn and checked, yes mine had a coolant tank and it is still down at the barn.
Looks like this one.
Expansion Tank - Auto Parts Warehouse Replacement
Someday I may order a replacement coolant tank, but I use my jeep mostly on the farm, it hardly ever gets to go to town.
wellmax is offline
post #7 of 19 Old 01-02-2010, 03:53 PM
Bubba Ray
My 84 has one on the drivers side fender.
Bubba Ray is offline
post #8 of 19 Old 01-02-2010, 08:27 PM
trillobite
My 85 CJ7 (2.5) had no coolant overflow, just the hose draped over the side of the radiator. It has one now, however, a cleaned-out gas tank from a snowblower, with vented lid.
My washer reservoir leaked, also. The washer reservoir from a mid-80's Nissan Pathfinder fits the spot above the ignition module, almost too perfectly. Hey, it's what I had at hand.
trillobite is offline
post #9 of 19 Old 01-02-2010, 09:20 PM
JCJ
You could have been an engineer with AMC,
Although I am a stickler for OEM with most things, I absolutely love finding stuff from other makes that fits and or functions better than stock. I feel sorry for whoever ends up with with my crap, I'm not leaving the decoder ring.
My 85 had one at some point, but was removed by the PO. Replacing it was one of the first things I did to it.
Keep in mind that the rad caps are different for expansion and non expansion systems.
"The arrogance of officialdom should be tempered and controlled, and assistance to foreign hands should be curtailed, lest Rome fall."
- Cicero -
55 BC
JCJ is offline
post #10 of 19 Old 01-02-2010, 09:37 PM
poppatello
My jeep didn't come with one either...
In a world full of copy cats, be an original...
Paved Roads
A Fine Example of Needless Government Spending
Originally Posted by berserker View Post
Sometimes it a good idea to pull a vacuum hose before the wife rides in it--you can tell her you need a new ____ and once you get your new ____ you can reconnect the hose. :)
84 Cj 7 w/ 4-Banger, 4.5" BDS lift, 1/2 Trans Drop, Twin Stick, 32" Tire, Front Aussie Locker, No Sound System Yet, No Armor, Warn 8274 Not Installed, Webber Carb Upgrade, Luckycheese Ing. Upgrade...
poppatello is offline
post #11 of 19 Old 01-03-2010, 12:03 AM
trillobite
Well, crap, what's the difference? Pressure rating?
post #12 of 19 Old 01-03-2010, 12:10 AM
JCJ
No, the cap for the expansion set up has a seal that contacts the top flange of the rad neck, the non recovery style will only have the "gasket".
Not sure if this picture will link or not..
- Cicero -
55 BC
JCJ is offline
post #13 of 19 Old 01-03-2010, 01:25 AM
kyle1228
1987 XJ Cherokee
Mine's a 78, & it didn't, hah. Had to put one in. Took me about 5 minutes.
kyle1228 is offline
post #14 of 19 Old 01-03-2010, 02:21 AM
Viencent
1982 CJ7
lol this tread made me go look at the new jeep, doesnt have one, added to the list of item to move over from my old jeep
Viencent is offline
post #15 of 19 Old 01-03-2010, 07:39 AM
trillobite
I've got the right one, then. Maybe mine was supposed to have a tank, and someone put in a older radiator. It wouldn't surprise me.
Coolant Overflow tank CJ-7 304 V-8 boomvader Jeep CJ Forum 11 01-05-2010 12:35 PM
Coolant Overflow? sprbeast Jeep CJ Forum 5 09-23-2009 09:25 PM
gas tank overflow billybooster2 Jeep CJ Forum 5 09-05-2008 10:02 AM
coolant overflow hose. spk454 Jeep CJ Forum 5 12-24-2007 08:46 AM
Coolant overflow tank... Goody1231979 Jeep CJ Forum 10 11-01-2007 08:34 PM
