Shortening the steering shaft - JeepForum.com
post #1 of 16 Old 10-17-2010, 08:39 AM Thread Starter
3S00W
2009 JK Wrangler
I would like for my steering wheel to be about 2 or 3 inches closer to the dash. I'm 6'1 and thick. I fit fine in my 5 but would like to be more comfy in my drivers seat. Has anyone ever shorten the colum?
3S00W is offline
post #2 of 16 Old 10-17-2010, 08:43 AM
Nereussailor
wouldn't it be easier to move the seat back?
I'm not sure what tomorrow will bring, but it can't be any worse than what I've already been through.
Nereussailor is offline
post #3 of 16 Old 10-17-2010, 08:52 AM Thread Starter
3S00W
2009 JK Wrangler
Cj5 seat is as far back as it'll go. Thought of that alrdy. Thx.
3S00W is offline
post #4 of 16 Old 10-17-2010, 09:36 AM
titomars
1981 CJ7
i am 6-4 and when i was shopping for a jeep looked a few 5's and quickly discovered i am not the best fit for one. the only working solution i came up with was cutting the fenderwell and making it shorter so the seat could mount further back. but gave up on that idea and i just decided to go with a 7. you might look into swapping steering columns and getting a tilt column.
titomars is offline
post #5 of 16 Old 10-17-2010, 09:52 AM
Skerr
It seems pretty straight-forward just thinking about it. If you do it, make a thread. Here is possibly another option. Buena Suerte!
Wheelhouse Notch | SSDutch CJ6 Jeep Blog | Boyink!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #6 of 16 Old 10-17-2010, 05:54 PM Thread Starter
3S00W
2009 JK Wrangler
I'm not thrilled about the wheel well trick. Is anyone in the know on how the OEM is for the steering column? If it's GM, you think swapping for a shorter GM column is an idea?
3S00W is offline
post #7 of 16 Old 10-17-2010, 06:25 PM
gojeepin
1983 CJ7
The steering column can be moved forward (and downward) by loosening the two bolts at the left and right of the base. The steering shaft will keep it from going very far.
The steering shaft is two piece and can be shortened. It is held together by two nylon "rivets" that allow it to collapse in case of a collision.
1. You can melt, drill, or punch them out to separate the two pieces.
2. Cut the inner shaft to the desired length.
3. Reassemble and drill your new holes on the inner shaft to insert the new nylon "rivets" or pins.
4. Insert the new pins
5. Move the column to its new location.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #8 of 16 Old 10-17-2010, 06:44 PM Thread Starter
3S00W
2009 JK Wrangler
I'm just looking for two or three inches here. you sound like someone who's maybe attempted this. Do you think that alone will get me the two or three inches w/o getting into cutting up the shaft?
3S00W is offline
post #9 of 16 Old 10-17-2010, 06:57 PM
gojeepin
1983 CJ7
No. I think the best you could get would be 1 inch.
To get 2 or 3 inches you'll need to cut the shaft.
You could look at aftermarket shafts but they're expensive and I don't know if they'll give you what you want.
gojeepin is offline
post #10 of 16 Old 10-17-2010, 10:50 PM
Deadman 94 xj
1977 CJ5
There is a big difference between my tilt column and my buddy's 74 non-tilt column for what it's worth.
If you do not have the tilt column I'd highly recommend that route and also buying a Grant wheel or similar with a shallow dish. The stock dish on mine was 3-4" deep IIRC. It was also 14.5" in diameter. I replaced it with a Grant wheel of 13" and 0" dish.
I'm only 6' 220 but I fit with room to spare.
77 CJ5. 304, t-150, D20
Deadman 94 xj is offline
post #11 of 16 Old 10-18-2010, 03:42 AM Thread Starter
3S00W
2009 JK Wrangler
I thought the steering wheel could help a little. I have a tilt and it can help some but not enough to get comfy.
3S00W is offline
post #12 of 16 Old 10-18-2010, 08:09 AM
Newjeep75
I had a '75 CJ5. I'm 6'2" and way too tall for the truck. I had my mechanic shorten the steering column by 4 inches. He never said that he had any problems and I think it was under $100.00 to do it. So it seems like an easy thing to do.
Then I cut out the rear wheel wells. Gained another 4 inches. After that everything was perfect, lots of room.
Todd.
Newjeep75 is offline
post #13 of 16 Old 10-18-2010, 08:21 AM
CSP
The column in your '75 (if it's the factory column) is quite a bit different and simpler thant he OP's '80 column.
CSP is offline
post #14 of 16 Old 10-18-2010, 08:34 AM
Newjeep75
Yup, could be. But I would take to a mechanic you trust for a quick quote. Couldn't hurt.
post #15 of 16 Old 10-22-2010, 04:45 PM Thread Starter
3S00W
2009 JK Wrangler
Well I've been at this for two nights now and I cant get it to move forward or back... hmm, iders...
3S00W is offline
Issue w/ Steering box/shaft/steering wheel alignment. SuperSportCJ Jeep CJ Forum 6 01-18-2016 07:24 PM
Upgrading to power steering; need to change steering shaft? Berretta Jeep CJ Forum 8 11-12-2013 06:12 PM
Replaced steering shaft-steering wheel 90 deg. out jshi218 Jeep CJ Forum 9 08-25-2009 07:39 PM
Coupler connecting steering gear to steering shaft is leaking? Natto123 Jeep CJ Forum 1 06-29-2008 12:52 PM
Trouble removing steering gear from steering shaft.... Natto123 Jeep CJ Forum 5 06-29-2008 10:56 AM
