Shop and Lift Equipment - JeepForum.com
post #1 of 6 Old 10-30-2015, 07:45 AM Thread Starter
bigred85
I'm curious what lift equipment everyone uses for "heavy" work on their Jeep. My floor jack is starting to fail and I'm shopping for a floor jack and maybe a cherry picker. I've seen both used for changing motor mounts, transmissions, transfer cases etc. Bang for the buck what do you use most often and what brand do you prefer? I was looking at this and seems pretty versatile: http://www.amazon.com/gp/product/B00..._gw_p263_d0_i1
bigred85 is offline
post #2 of 6 Old 10-30-2015, 08:52 AM
texasdave
texasdave's Avatar
1980 CJ7
I would look to see if it is capable of attaining the height to get you vehicle high enough to get jackstands under it and be comfortable.
texasdave is offline
post #3 of 6 Old 10-30-2015, 09:00 AM
ChrisHager
Administrator
ChrisHager's Avatar
As texasdave points out, make sure the jack you're looking into will handle the vehicles you're working on.
My father-in-law bought me one of these a year or so ago. I love it. It's low enough to slip under cars and reaches tall enough to pick up my lifted J-10 by the frame and hang both the front and rear tire. It'll lift a quarter inch shy of 2'.
http://www.harborfreight.com/2-ton-l...ump-60678.html
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #4 of 6 Old 10-30-2015, 10:15 AM
wm69
I've got a harbor freight big floor jack too. I thought it would be a POS that would crap out after a couple of years. It's about 10 years old and still works great.
wm69 is offline
post #5 of 6 Old 10-30-2015, 10:41 AM
OrangeCJ-5
1978 CJ5
Harbor Freight 2 ton aluminum and 3 ton Sears floor jacks. I also have/use a couple pairs of 3 ton and 12 ton jack stands depending on the height that I need to set it at.
OrangeCJ-5 is offline
post #6 of 6 Old 11-01-2015, 04:48 PM
muddypunk
1995 XJ Cherokee
3.5 Ton HF low profile Jack I love it 3.5 inch rest hight 29 inch fully pumped up.
sent by my Arse because my hands are full.
muddypunk is offline
