#1 | |
Shock question
Well after about 6 weeks of being parked my CJ is rolling again. Rain, cold weather and sickness all slowed the process down a bit and with the help of a fellow jeepfourm member and friend, LSUtiger, its once again ALIVE. The total project included a 4.5 inch RE lift and a Navajo break upgrade with new pads, shoes, wheel cylinders and calipers. Also replaced the drag link and tie rod with a Rugged Ridge set and did a tie rod flip.
The mono tube shocks that I ordered with the RE kit look to be to small. I am sure the lift is going to settle a bit, however currently when it is parked in the driveway the shocks are only a inch or so longer than the mount. I believe installing them like this will limit my travel. In the next few days I plan on sticking some jack stands under the frame and measuring the full length of downward travel. How much longer that full travel should they be?
#2 |
they should be about an inch or two longer than full travel
#3 |
Don't know if this is standard, but IIRC I went 2" longer than my measurements.
If you have a swaybar, you might want to disconnect it before measuring. RE is has pretty good customer service and they will probably just swap out the shocks for longer ones. ------- |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
