#1 | |
Shock Mount Help
Wanted to replace the top bolt / hardware for the rear shocks while I have the tub off. Not buying new shocks yet (the spending is adding up) but thought it would be a good idea to replace this hardware since it is pretty much rusted on, and fresh hardware would be easier to remove a year from now.
I cut the bolt to get the shock off - but as you can see in this pic I can't knock it out of the mount! Does it even come out or do I need new hardware to weld on all together? http://s252.photobucket.com/albums/hh9/kbonsig/th_IMG_2579.jpg
2003 TJ RUBICON (CURRENT) 1985 CJ7 I6 2000 TJ I6 1995 YJ 4Cyl 1987 YJ I6 |
#2 |
That is not meant to come out. You can either drill it out and fab something up or find a used one.
Craig |
#3 |
I think MORE sells weld on replacements - does anyone know where else I can get a pair? 4WD Hardware does not sell them.
#4 |
Those front or rear mounts? Those look like rear there are these on ebay.
Found these also original nos one but still no bolt. http://collinsbros.stores.yahoo.net/76cjrefrshmo.html You would still have to find a bolt that works. I would just drill/cut out the one thats there and weld a new one on. Craig Last edited by craigb86; 08-12-2008 at 06:45 PM.. |
#5 |
GROUND POUNDER
I just made some shock hoops for my CJ5.. I'm goint to plasma the stock Narrowtrac (short) front shock mounts off the frame in a few days. If you want them, I can try to be careful with the removal so they can be welded back on. I think they're in good shape. Just let me know..
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s.. Lower 2 Guardrail Down Schoolbus Slickrock Tellico Save Crozet More Crozet |
#6 | |
#7 |
GROUND POUNDER
Not sure if they're exact but I think they'd work. If I can remember, I'll take a closer look on my CJ today.
#8 |
I think it will work - looks like I may have to shave off a little to make it a flush fit - I'm going to give it a shot. Let me know what you think if you check out your CJ.
Thanks!
#9 |
You might try to carefully cut and drill the old shock stud off, and replace it with a "bolt on" shock stud. My AFW (now TDK) CJ8 frame is set up with bolt on shock studs in the rear. A decent parts store should be able to help with replacement studs. May be easier than welding on a new bracket.
#10 | |
I have a welder coming here next week to do some frame work - just dropped $400. more on various parts (I should be done now) including the cj5 shock mounts. I can't deal with anymore rusted bolts between my old tub and this frame - my build would be much more enjoyable without all this rust.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
