Quantcast Shock Mount Help - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Shock Mount Help
Great deals on Mickey Thompson Tires @ Jeephut.comOfficial Chassis Saver Rust Preventive Truck & Auto UnTJ 5.25" Speaker Adapters - NalinMFG
Old 10-23-2007, 12:21 PM   #1
DuggerCJ
1975 CJ5
Shock Mount Help
I am doing a restore on a 75 CJ-5. It had a homemade SOA when I started. I am now putting it back togther. Th top shock mount was already on the frame.
However the lower mount was not in place.
The upper mount is not directly above the lower plate where the lower mount should be. Should it be? And.....Where on the lower plate should I weld the lower mount?
any feedback will help.
Time is a good teacher....unfortunately it kills all its students
DuggerCJ is offline   Reply With Quote
Old 10-23-2007, 12:53 PM   #2
spk454
1983 CJ8
the factory mount is on the spring plate. you can use a factory spring plate flipped upside down and on the other side or weld mounts to the tube. some of the aftermarket spring plates also have studs on them to accomodate the shock mount, they are beefier than the factory ones. factory ones look like this...
http://shopping.jeep4x4center.com/popup.asp?number=5363439
spk454 is offline   Reply With Quote
Old 10-24-2007, 11:12 AM   #3
John Strenk
What was I thinking
1976 CJ5
Nice brace between the frame. Add that yourself?
If it was mine, I'd figure out how far the springs would flex. Then pick a shock with enough travel. Yo may find out you made need a longer shock body which will mean a different mounting both top and bottom.
You can use an 84 of later CJ shock mount that bolts to the frame to allow the shock to be mounted a little higher or evn some off a F-150.
Then you can figure out were to weld a lower mount on. 84 and later mounted directy to the axle. The axle was wider in 84 also making it easier what width are yours?
Now if I just needed something cheap to get running i would probably do what spw454 recomends but then you would be limited in how far you cna flex before the shocks bind up. Possibly stock lengthe or a little less.
John Strenk is online now   Reply With Quote
Old 10-24-2007, 12:07 PM   #4
DuggerCJ
1975 CJ5
thanx John. The brace was on the Jeep when I bought it. They PO had also boxed in the frame.
For longer shocks, they will not mount to the standard shock mount like the one in the pic?
Another user suggested using 2"x1/8" pc of square steel, cutting into shape of a bracket, drilling hole...etc. And welding it to the axle tube. Is this also a problem with longer travel shock?
Scott
Old 10-24-2007, 12:31 PM   #5
Bigjeep65
1982 CJ7
Several companies like MORE and RE sell Do It Yourself shock tabs that will weld onto the axle tube. It is easier with a wide track axle, but it is also do-able on the narrow track axles.
As mentioned above, changing the upper mount as well would allow a longer travel shock, and thus more suspension travel (more flex).
From the picture, it appears you have the factory upper shock mount used pre-'82 models.
The shock mount diameter I believe is the same.
Bigjeep65 is offline   Reply With Quote
Old 10-24-2007, 12:52 PM   #6
jayhawkclint
1970 CJ5
I'd recommend a set of weld-on shock mounts. Here is the link:
http://www.quadratec.com/products/92000_000.htm
I also did this on my '70. Note that your shocks mount to the rear of the axle on the '72-'75 models, but otherwise should be the same as pictured below. (Look off to the right side of the pic just past the u-bolt.) For your particular application being SOA, this will also allow you to run a slightly longer shock compared to using a stock spring plate flipped upside-down.
My '70 CJ5 Build Thread:
http://www.jeepforum.com/forum/f22/my-jeep-build-thread-359375/
jayhawkclint is offline   Reply With Quote
Old 10-24-2007, 01:35 PM   #7
John Strenk
What was I thinking
1976 CJ5
Scott
Yes it will but the longer shock has a longer body so if you put it in the present location, you will bottom out the sock sooner than with the original shock (Shorter Body) . But if you use the stock length tube then you won't travel as far.
So to use the right length shock you will have to mount the ends farther apart.
Old 10-24-2007, 01:50 PM   #8
dirtbagofva
2010 JK Wrangler
i saw some where that you can bolt on Ford shock mount on the frame to add more length to the shock travle (extending the upper mount). What you need to do is measure full droop and full compresion and get a shock that can travle a bit further.
"It is a damned poor mind indeed that can't think of at least two ways of spelling any word."
Proud owner of 2010 JK, 1994 XJ and an 81 CJ-7
dirtbagofva is offline   Reply With Quote
Old 10-24-2007, 03:13 PM   #9
Bigjeep65
1982 CJ7
In his picture, he is SOA (read as not stock). I can't find a reference to his shock length above so:
In order to maximize the suspension travel, the shock must travel the full range of the suspension motion.
A shorter bodied shock will have a shorter piston length, and total travel will be less than a "longer" shock.
To determine what he needs for his setup, he would need to measure from mounting point to mounting point in the compressed suspension position and again in the extended suspension position. He would then want a shock that would collapse/extend to those measurements.
If a shock could not be found with the range need, then moving the upper shock mount farther away from the lower shock mount would allow for a longer shock with more travel.
Both the newer CJ's ('82 - '86) front shock towers and the Ford F-250 shock towers would give this option.
Cliff notes
Shock body = 10" long, maximum length of shock fully extended = ~20"
Shock body = 14" long, maximum length of shock fully extended = ~28"
Longer shocks allow more more suspension travel, when the shock is the limiting factor.
Old 10-24-2007, 03:17 PM   #10
slacker92104
Look for a set of late model f-250 shock towers. They are very tall and fit well. You can get them from the dealer for about $15 each.
'81 CJ5, efi 302, AX-15 5 spd, On Board Air, wrangler spring conversion, Astro van Hydro Brakes.
Soon: Custom cut Dana 44 front, wide trac solid axle amc 20 rear, SOA,
slacker92104 is offline   Reply With Quote
Glock Forum
