Shock length - JeepForum.com
post #1 of 7 Old 03-02-2008, 09:12 PM Thread Starter
supraman1990
supraman1990's Avatar
1980 CJ5
Shock length
I got some shocks for my 4 inch lift in my CJ, and they are far too short. They are the trailmaster's that quadratec suggested for my amount of lift. Does anyone know if I can get some for 5 inches of lift and have any problem? The 4 inches are just too short, and they are going to limit my flex. Let me know guys.
80 CJ5 in the process of a frame up resto
96% complete.
The little stuff will kill me.
On the back burner for college.
supraman1990 is offline
post #2 of 7 Old 03-02-2008, 10:56 PM
jeepskate
Best bet is to flex out your rig and measure to see what you need for collapsed & extended length.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #3 of 7 Old 03-03-2008, 04:19 AM
rmc429
what do you do then-- get a shock in the middle? I know that sounds stupid, but you know what they say about there are no stupid questions. I am not really sold on that because i see some real good ones on here from time to time
rmc429 is offline
post #4 of 7 Old 03-03-2008, 05:19 AM Thread Starter
supraman1990
1980 CJ5
I'd have to take my shocks I have now completely off in the front and probably the back to get it to flex all the way out. Any other ways of determining what I need?
96% complete.
post #5 of 7 Old 03-03-2008, 11:24 AM
SuB8HaVeN
If you look on Summit Racing's website, they have the applications for all of their shocks listed. When I bought my Skyjacker shocks for my CJ I looked at all of them and ended up getting shocks for a 1-3" lift or something like that, because the factory length shocks wouldn't work. You should be able to find CJ shocks specified to work with a 4" lift and they should work.
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress)
1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress)
SuB8HaVeN is offline
post #6 of 7 Old 03-03-2008, 12:08 PM
jeepskate
Anything else is gonna be a guess, which is what you already have. You could look up the specs on your shocks and compare them to what another manufacturer offers for a 4" lift...you may find some glaring inconsistency.
post #7 of 7 Old 03-03-2008, 12:13 PM
jeepskate
A shock in the middle of what? You'll get two measurements from the distance between your shock mounts...the shock specs will include the same measurements (not necessarily the exact same numbers you got, but a collapsed and extended length). You pick something that has enough travel to not bottom out before your suspension does and not be fully extended before your suspension reaches full droop.
Shock length question, stock and 4" lift Coiz Jeep CJ Forum 3 10-24-2008 05:59 PM
?? about right shock length aero mech Jeep CJ Forum 1 07-12-2008 08:39 PM
amc 20 length muddmonky Jeep CJ Forum 7 03-13-2008 01:35 PM
Build plan/Engine length/Transmission length collinpyle Jeep CJ Forum 13 06-22-2006 08:01 PM
Shock length grady adams Jeep CJ Forum 5 10-18-2004 07:11 AM
