Shock Boots, Good or Bad? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Shock Boots, Good or Bad?
Jeepforum Coupon for Iron Rock Off RoadRuffstuff Axle Simple Swap Kit!Our Panhard / Trackbar brackets, Variations......
Unread 09-01-2008, 08:19 AM   #1
Rezneck
I think they catch and hold more crud than they keep out.
My grandson helped me change shocks yesterday and we put the boots on. I guess they look cool and they wouldn't have came with the shocks if they weren't needed. I'll take them back off sometime when he's not looking.
Throw the bums out!
48 CJ-2A, Bone stock except it has Allstate locking hubs.
86 CJ-7, 4.0 HO, AX-15, D-30, AMC-20
84 CJ-7, YJ tub and fenders, 258 ci, T-176, D-30, D-44 Trutracs F/R, 4.27s, 33s
77-90ish Wagoneer/TJ/CJ Yard Sale Special, 360AMC, TH400, Quadratrac, D-44s F/R, 3.07s, 34" LTBs.
Rezneck is offline   Reply With Quote
Unread 09-01-2008, 11:30 AM   #2
OldSailor
1977 CJ7
I've never used shock boots on he shocks or steering dampers on my CJ7. I think it tends to trap the water in there, promoting rust of the piston rod.
1977 CJ7, AMC360 V8 w/ headers, DUI HEI, Edelbrock intake, Holley 4150 carb, , TF999, D300, D30 front and AMC20 rear with 4.56 gears and lockers both ends, 4" susp lift, 2.5" body lift, 35" BFGs, ARG steering, 8000-lb winch, etc.
OldSailor is offline   Reply With Quote
Unread 09-01-2008, 11:34 AM   #3
243
243's Avatar
1983 CJ7
If they are sealed to hold nitrogen in, that should keep dirt and liquids out....that's my story and I'm sticking to it
1983 CJ7
258/T177/D300 3.54 32" BFG KM2
THE BEGINNING:
http://www.jeepforum.com/forum/f8/da...2/#post8211912
In the 80's we had Reagan, Bob Hope, and Johnny Cash
Now we have Obama, no Hope, and no Cash
243 is online now   Reply With Quote
Unread 09-01-2008, 04:17 PM   #4
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I don't bother with the boots anymore. They've always ended up full of crud or ended up getting ripped up. I'd rather give the shock a good spraydown with clean water than rely on a boot to keep it clean.
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Unread 09-02-2008, 07:37 AM   #5
84jeepjohn
well, my shocks have never had the boots, and the rod is ALL rusted now. Granted I think alot of it started when I was stuck in Iraq, but still... I think boots (with a drain hole) are a good idea
84 CJ-7 RE 4.5" lift TJ flares and 35"BFG's
4.88's and OX lockers front and rear
2000 Grand Cherokee, 2" lift, BFG AT's (SOLD)
2005 Z71 Suburban with 1.5" rear spacers, and front leveled
84jeepjohn is offline   Reply With Quote
Unread 09-02-2008, 03:45 PM   #6
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Just curious.. what brand shocks?
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
Unread 09-02-2008, 04:04 PM   #7
Slawth
Utility Master Rebater
Slawth's Avatar
1978 CJ5
Boots hold moisture and crud in. You then can not see the crud while it wears away at the seal around the rod- or causes rust/pitting. The only time you should run shock boots is if they are florescent pink. Then their entertainment value for other Jeepers far outweighs the damage they might be doing.
The End
Slawth is offline   Reply With Quote
Unread 09-03-2008, 03:07 PM   #8
84jeepjohn
what ever came with my RE 4.5" lift back in 01
Unread 09-10-2010, 11:55 AM   #9
78CJFIVE
1978 CJ5
Thanks search function.
I was about to make a new post about this, but I'll bump this one. I just got a new 2.5" Superlift w/ shocks, and after inspecting my old shocks I came to the conclusion that the boots trap a lot of crud. I've decided not to run them. Wasn't crazy about the yellow color anyways.
Off topic.. I had planned on using a better shock, but decided to save a few bucks here. What do you guys think about the Superlift shocks?
78CJFIVE is offline   Reply With Quote
Unread 09-10-2010, 12:30 PM   #10
gojeepin
gojeepin's Avatar
1983 CJ7
I went a different way. I just bought some Monroe shocks that have the (old style) steel caps over the rod instead of a boot. They keep most of the dirt (etc.) out and don't trap anything inside.
The yellow you see on the front wheel of my Avatar is the shock cap.
Vibration? Bump steer? Wandering? Read: Steering, suspension, and driveline basics. An article on how it works and where to look for problems.
83 CJ7, 4.1L 6cyl (4.0L bored .030" over), 35" tires, T-5 transmission, Dana 300 TC, Trussed AMC 20.
gojeepin is offline   Reply With Quote
Unread 09-10-2010, 12:42 PM   #11
Torxhead
I called Rancho on that question back in the day when they were the only shock to get. They said definitly to install them.
Torxhead is offline   Reply With Quote
Unread 09-10-2010, 10:05 PM   #12
78CJFIVE
1978 CJ5
Here are my old Rancho shocks. They have always had the boot installed. You an see the clean white area is where the boot was ziptied to. The rod is hasn't rusted, but you can see all the debris the boot held in and what it did.
Unread 09-11-2010, 07:39 AM   #13
Skerr
Jeep Vacuum
Skerr's Avatar
Having been born in FL and growing up on the beach, I will go out on a limb and suggest your Jeep had ridden on the beach once or twice in its lifetime. And unless you scrub with a sponge and soap you will never get ALL of the salt off.
The important factor about a shock that needs to be considered is the condition of the piston. That's the shiny "stem" that you can see (or not if you have boots). Keeping the piston in good shape significantly extends the life of a shock. If the piston rusts it will cause pitting in the metal. As the shock operates normally the pitted metal may move back and forth across the seal, causing the seal to wear out and leak. This is true in all hydraulics. Boots may hold in crud, but if the piston doesn't rust it's a moot point. I think it's a matter of personal preference.
Kerrdog
Go Fish! <*////><
It's AMAZING what you can accomplish if you don't worry about who gets the credit.
Clay's Build Thread
http://www.jeepforum.com/forum/f8/cl...hread-1061897/
Scott's Build Thread
http://www.jeepforum.com/forum/f8/sc...5-cj7-1147913/
Fallon (and Dad) Build Thread
http://www.jeepforum.com/forum/f11/f...-okee-1445206/
Skerr is offline   Reply With Quote
Unread 09-11-2010, 08:31 AM   #14
84jeepjohn
LOL no I've only been in FL for about 1.5 years (military) and this CJ has never gotten to go on the beach. They don't let us on the beach in my area.
all my issues started in south texas, and then OK LOL but since moving to FL the rust has accelerated
Unread 09-11-2010, 08:56 AM   #15
Skerr
Jeep Vacuum
Skerr's Avatar
Well... it's inherrent in FL. We're a rusty state! I'm glad you're here and thanks for your service!
Kerrdog
Go Fish! <*////><
Clay's Build Thread
