shifter vibration - JeepForum.com
post #1 of 4 Old 10-08-2003, 10:33 PM Thread Starter
edge1
shifter vibration
My 86 CJ7 (4 sp manual) has just developed a severe vibration in the two shifters in third gear only, about mid way through the rpms. It is not happening in any other gear or at hwy speeds. I put on a new set of OME springs with about 2" of lift several weeks ago (things had been ok until now). What could be the problem?
edge1 is offline
post #2 of 4 Old 10-09-2003, 07:13 AM
jadams68
jadams68's Avatar
Problem may be that when you lifted the jeep, you threw off your pinion angle enough to produce driveline vibrations.
However, I'd check the following first.
a) Transmission mount is failing or broken.
b) Motor mount(s) need replaced.
You could drop the transfer case about 1/2" with a t-case lowering kit.
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #3 of 4 Old 10-09-2003, 09:21 AM Thread Starter
edge1
The engine and tranny mounts are both new (along with my rebuilt engine). From what I have been told, the angle should not be a problem until you get close to 3" of lift. It's worth a shot, though.
edge1 is offline
post #4 of 4 Old 10-09-2003, 09:31 AM
jadams68
jadams68's Avatar
Take it to the shop that did the work and ask them to measure your pinion angle on the rear pumpkin. It'll take 5 minutes and then you'll know definitively if that's your issue.
jadams68 is offline
What is the thread size of the manual shifter and 4wd shifter? HHICJ7 Jeep CJ Forum 7 09-25-2009 01:05 PM
column shifter to floor shifter TJbino4 Jeep CJ Forum 0 09-14-2007 06:25 AM
Transfer case, the big shifter, the little shifter, and oddness senaTTor Jeep CJ Forum 10 10-17-2006 07:52 PM
Vibration at 35 MPH and up - HELP !!! sbestmann Jeep CJ Forum 6 08-22-2003 06:33 AM
New T176 shifter pins and shifter fork!! sampson9dk Jeep CJ Forum 0 06-17-2003 03:20 PM
