Shift On The Fly? What gives? - Page 2 - JeepForum.com
post #16 of 18 Old 01-03-2010, 04:57 PM
72jtruck
1972 FSJ Gladiator
I shift my 18 in my CJ5 at speed sometimes. I dont even press the clutch. I just shift it and it seems to work fine. I always leave my hubs locked, because I use it on the trail more than anything, but i have never noticed a difference in gas mileage or any wear.
1969 CJ5 1972 J2000 thriftside
1979 J10 1993 ZJ Limited
72jtruck is offline
post #17 of 18 Old 01-03-2010, 05:44 PM
JeepnBlake
Plus, as I'm sure you notice as I have with my plow, adding 800# to the front ends tends to give you a little more traction up front.
I don't even bother with the clutch to go from 2 to 4 unless some end is spinning.
Right you are sir, not to mention the extra 600 lbs in sand in the back.
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #18 of 18 Old 01-03-2010, 08:13 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
One thing to remember, if your running with the hubs engaged a lot you will want to service those spindle bearings. These things are never lubed and water gets into them either rusting them solid or causing the bearings to disintegrate. At highway speeds this can eat your stub axle or ruin your locking hub. It will also cause all kinds of vibrations.
jeepdaddy2000 is offline
dana 18 twin shift cant shift it into (out) from the in tpamouse Jeep CJ Forum 9 12-18-2009 06:49 PM
cant shift out of first zeronight Jeep CJ Forum 3 12-09-2009 01:43 PM
Shift kit for 999 143hc Jeep CJ Forum 0 01-14-2008 04:51 PM
She won't shift.. Gumy Jeep CJ Forum 4 09-10-2007 07:44 PM
t 18 won't shift the shootist Jeep CJ Forum 4 09-04-2006 07:59 PM
