Shell Rotella only for break-in?
| Brand new! XJ Rear DIY Bumper from JcrOffroad! | Spartan Lockers FREE SHIPPING Excellent Prices | GR8TOPS Introduces the Exogate HD Tire Carrier |
#1 | |
I have been running rotella in my 360 for about 7000 mi, because of the added protection for flat tappet cams. Yesterday, I was watching a Speed channel hot rod show, and when talking about oils, they said that while rotella was a good break-in oil, it would cause sludge build-up if used long term. Is this true,and if it is what would be a good oil to use in a carburated amc 360? Thank You.
#2 |
I've been using Royal Purple 10W-30 in my AMC 360 for about 10 years of so. No problems with it. However, I change it every 1000 to 2000 miles because my CJ7 is basically an offroad machine.
1977 CJ7, AMC360 V8 w/ headers, DUI HEI, Edelbrock intake, Holley 4150 carb, , TF999, D300, D30 front and AMC20 rear with 4.56 gears and lockers both ends, 4" susp lift, 2.5" body lift, 35" BFGs, ARG steering, 8000-lb winch, etc. |
#3 | |
FOR SALE - 1960 Willys CJ3B - Odd Fire V6 - T177 - Dana 300 - D30 - D44 - 33x12.50 Super Swampers |
#4 |
You will hear a lot of feed back on preferences on oils. Some will say regular oil and some will say synthetic. Currently I am running 10-40 with an additive called ZDDP Plus ( http://www.zddplus.com/ )
I figure just putting back the ZDDP in the oil is the simplest thing to do to make the oil similar to oils of the past. The EPA is also making the oil manufactures lower the ZDDP in the Diesel oils. And while some people swear by Rotella the diesel engine is a completely different animal so the additives are different. I was waiting for some long term usage results before I considered changing. |
#5 | |
SEAL Team VI
http://www-static.shell.com/static/ca-en/downloads/shell_for_businesses/oils_lubricants/rotella/rotella_fact_sheet.pdf
'77 CJ-5 Renegade 304 / T-150, Dana 20, 30/20 axles, American Racing 15x10 Outlaw II's, 33" Dynapro M/T's" ,Optima Battery, TeamRushed + Summit Racing CDI ignition, 575 Flex-A-Lite, FlowKooler, Edelbrock Performer Intake Manifold, Holley 4160 390cfm, Herculiner, Silver Ceramic Coated Hedman Hedders, Flowmaster 40's. |
#6 | |
#7 |
for what it's worth...used Rotella in my diesel Suburban for 13 years and 215,000 miles. No problems, no complaints.
#8 |
One more thought, although I love to watch the car shows on Speed and Spike TV on Saturday and Sunday mornings, do you believe everything that is presented there? I mean, they advertise Z-Max as well...
I had thought that Shell reduced the amount of zinc and phosphorous in Rotella like many other oils recently. Those are the components needed for flat tappet cams to survive long term. I still use a ZDDP additive unless the manufacturer specifically states they have it, like Royal Purple or Joe Gibbs oils. Dave |
#9 |
It would be interesting to see some hard facts. Sludge seems to only be a relatively recent problem, with a number of modern motors being particularly susceptable. I forget the reasons I've seen stated but one of them was the additional heat and the fact of running a much leaner mixture. I just don't remember hearing about sludge prior to the mid 80's. So it would depend on the type of motors they are talking about with regards to sludge build up if Rotella is used beyond a break in period. I believe sludge is a problem for lean burn gas motors not diesel so Rotella may not have the additives used to fight sludge in other oils.
I think if you change your oil regularly then sludge is not an issue. I also struggle to believe that a modern oils, which have added so much to vehicle longevity from when I first started driving, even with the deletion or depletion of additives would give poorer performance than the oils from the 70's regardless of flat lifters, but then what do I know, and as I've said before, we have no way to test this as individuals. |
#10 | ||
Most vehicles nowadays have roller lifters instead of flat ones. These are designed more durability because of this, so they don't need the extra wear inhibitors.
http://www.jeepforum.com/forum/f8/ricks-build-thread-78-cj5-1223197/ |
#11 |
Sounds like BS to me. What do you think tractor trailers run in their motors, and they go half a million miles?
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress) 1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress) |
#12 |
Cutlass your pretty close on that last comment. Actually the EPA mandated that a Catalytic Converter last longer than a 100K Miles. And they found that zinc was masking the converters thus decreasing efficiency and zinc being a scrafical metal for the camshaft forced the car manufactures to switch to rollers. So it wasnt about durability it was about warranties.
#13 |
Rotella is one of the best oils out there. It does not create a sludge buildup. I have switched all my vehicles to Rotella including the Honda Civic. I have also been breaking all my new engines in with Rotella and a Comp cam additive if using a flat tappet cam. After break-in, it's straight Rotella. After 3500 miles in between oil changes, this oil still looks very good. The zinc and phosphorous count has been lowered in the Rotella too like all others, but it still has an extremely higher count than other conventional oils and the same amount as some of the racing oils. Other good oils to use is Valvoline VR1 race oil or any oil that has a label that states "For Offroad Use Only". Rotella has the same count of ZDDP and it's much cheaper than the race oils. I will say my street/strip engines have held up great with the VR1 oil. Now I will see how the Rotella does, long term, with a little more testing. So far no complaints.
1979 Jeep CJ5 Silver Anniversary - 305ci Chevy With TH350 Trans, 268H Comp cam, 570 Street Avenger Holley, Hedman headers, Super 40 Flowmasters, 2 1/2 Rancho Lift, 15x10 Eagle Wheels, 33x12.50 Mickey Thompson Baja MTZ Tires, Custom Full Roll Cage, Line-X Interior, Custom Rock Crawler Bumpers, Bestop Trailmax Seats, Autometer Gauges, Bestop Supertop. Webpage link: www.freewebs.com/chromed88ss Last edited by Performance; 05-12-2009 at 12:18 AM.. |
#14 |
Running On Empty...
I think many are missing the point here...
Shell Rotella and Valvoline 15W40 are INDUSTRIAL GRADE OILS. They have to live up to high standards of cleaning, particle suspension, detergents, thermal shock, friction breakdown, ect. than 'Consumer' grade oils do. It's just 'Built' better than the light weight oils, keeps the engine cleaner, and it simply is TOUGHER than 'Consumer' oil is.
REMEMBER, 'Free' internet information is worth EXACTLY what you paid for it! LINK:Dual Battery Diagrams & Explanations. LINK:Winch, Welding, 'Lend Power' Project, LINK:Water Proofing Ignition, Hubs, Ect., LINK:BSERK's Winch Plate, LINK:AMC V-8 Front Cover Recondition, LINK:How An Ignition Works, LINK:Ignition Swaps '77 Older Jeeps, LINK:'78-'90 Jeep Ignition Upgrades, |
#15 | ||
An article I came across recently.
http://www.highperformancepontiac.com/tech/hppp_0802_pontiac_performance_engine_oil/comp_cams.html Quote:
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
