She wont start - JeepForum.com
post #1 of 24 Old 11-10-2012, 05:21 PM Thread Starter
Quailguy
She wont start
Evening gents. Got everything back on my 7 today. Tried to fire her up but only got the fast buzzing noise like when the battery is low. I checked it with a multimeter and it showed 12.51 volts. It's a year old battery that worked in this Jeep 2 weeks ago. I cleaned the posts and cables Any ideas?
Quailguy is offline
post #2 of 24 Old 11-10-2012, 05:39 PM
cjjon7
1983 CJ7
Loose connection somewhere. Check the starter solenoid connection, grounds, otherwise its still the battery!
cjjon7 is offline
post #3 of 24 Old 11-10-2012, 05:47 PM Thread Starter
Quailguy
Cleaned those first. Would it turn over at all if the ground was bad?
Quailguy is offline
post #4 of 24 Old 11-10-2012, 05:51 PM
cjjon7
1983 CJ7
It may. All depends on the condition of the battery. The more corrosion, the more resistance for the current to power through
cjjon7 is offline
post #5 of 24 Old 11-10-2012, 06:51 PM Thread Starter
Quailguy
I think everything is clean. How will I know if it is the battery since it reads 12 volts? What should I try next?
Quailguy is offline
post #6 of 24 Old 11-10-2012, 06:53 PM
cjjon7
1983 CJ7
You would need to load test the battery, or try a battery that you are sure is good.
cjjon7 is offline
post #7 of 24 Old 11-10-2012, 07:14 PM Thread Starter
Quailguy
I really appreciate your help. How do I load test it? I just want to get it fired up so I can smog it Monday. It's been a year in my garage and the granddaughter is getting impatient.
Quailguy is offline
post #8 of 24 Old 11-10-2012, 07:22 PM
cjjon7
1983 CJ7
I compretely understand, I can't wait to drive mine again! As far as I know, in order to load test you would need a load tester. It basically tests the guts of the battery to ensure they're still producing a charge. Typically a battery that is bad will read less than 12 volts, however sometimes not. You can take the battery to autozone and they can bench test it for free for ya...prolly the easiest way.
cjjon7 is offline
post #9 of 24 Old 11-10-2012, 07:59 PM Thread Starter
Quailguy
I'll do that tomorrow, right after the morning quail/dove hunt. Thanks again.
Quailguy is offline
post #10 of 24 Old 11-11-2012, 03:09 AM
RWise
1981 CJ5
If you have a helper you can do an at home test, measure the voltage at the (fully charged) battery (post not terminal) while cranking, it should not fall below 9vdc with the starter turning. Not as good as a real load test, but will show if it is the problem, and you can work your way toward the starter to find the bad connection.
RWise is offline
post #11 of 24 Old 11-11-2012, 05:09 AM Thread Starter
Quailguy
The more I think about it, the more I think it's the battery. It's a couple years old but has had little use. The part that gets me is that it was working fine 2 weeks ago. I think my dash clock drained it, but all day on the charger didn't seem to help. Only other change was connecting the engine warning light but don't see an issue there. Thanks guys for the help.
Mike
Quailguy is offline
post #12 of 24 Old 11-11-2012, 11:01 AM
FishnWishn
1973 CJ5
Looks like I have the same problem. Just clicks then no power. Charged it overnight. Checked battery- 13.9 vdc, load it goes down to .09vdc. hooked up my charger in start mode and fired right up. This is my excuse to get a red top optima battery
FishnWishn is offline
post #13 of 24 Old 11-11-2012, 12:03 PM Thread Starter
Quailguy
I just tried The load test in the Jeep suggestion. Dropped to 3.5 dcv, so I guess that means I can get a red-top too!
Quailguy is offline
post #14 of 24 Old 11-11-2012, 12:59 PM
FishnWishn
1973 CJ5
Advance auto parts has 25% discount on batteries, got $51.50 off the cost. Ordered it online and picking it up at the store after the game.
post #15 of 24 Old 11-11-2012, 01:03 PM
frhrwa
Fish'n Fool
frhrwa's Avatar
take it to Sears, AutoZone, or one of the supply parts stores... they will test it for you... also might look at the starter solenoid if the battery turns out good.. if its a manual trans, you can rock it in gear to move the solenoid and flywheel to see if its just in a bad spot..
oops, sorry didn't finish reading all the rest of the replies...
I want to die in my sleep like my grandfather, not screaming in terror like the passengers in his JEEP!...
frhrwa is offline
