Shackles for military wrap springs - JeepForum.com
post #1 of 3 Old 06-27-2002, 06:20 PM Thread Starter
Jeep Daddy
Jeep Daddy's Avatar
Lightbulb Shackles for military wrap springs
Does anyone know what shackles to buy if springs with military wrap are used. I'd like shackles about 1 1/2" over stock.
Also, can someone describe the difference between military wrap springs and standard springs.
Thanks
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #2 of 3 Old 06-27-2002, 07:12 PM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
Cool
You can use any shackles you like. Personally, I don't like them that tall, really 3/4" is the most I would do, you start to mess up your camber angle with them, plus total lift achived is only 1/2 of the listed amount, as you only are "lifting" one side of the spring.
I'm very happy with my greaseable shackles, they do help smooth the ride a bit. Many companies make good ones, Currie, etc.
Military wraps use a longer 2nd (from the bottom) leaf that wraps around the first leaf as that first leaf is wrapped around the bushing. It's like having two bottom leaves, both of which form a circle at the end and create the attaching point to the shackle.
Some older jeeps had these as stock, but they might be overkill for all but the heaviest and hardest-core rigs. Due to the fact that the two leaves act more like one, with less ability to slide on each other, the ride is usually stiffer.
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #3 of 3 Old 06-27-2002, 11:49 PM Thread Starter
Jeep Daddy
Jeep Daddy's Avatar
Post
Thanks for the description of the military wrap springs. That makes much more sense to me now. Your description was very accurate and easy to picture. Thanks
Axle wrap collapsing shackles? kstopp Jeep CJ Forum 9 09-09-2008 06:56 AM
Military Wrapped Springs onesourcemike Jeep CJ Forum 15 06-23-2008 03:18 PM
military wrapped springs..whats the deal with them? Mr.Crowley Jeep CJ Forum 5 11-03-2006 04:13 PM
shackle for military wrap springs malpi Jeep CJ Forum 1 10-30-2006 11:43 AM
Shackles for Reversal w/ YJ Springs? MudLover Jeep CJ Forum 2 02-16-2005 09:48 AM
