Shackle Reversal System - JeepForum.com
post #1 of 6 Old 09-24-2011, 10:18 PM Thread Starter
ctappan94
1983 CJ7
I just realized my CJ has reversed shackles... I took them off to do my restore anyway...but can someone tell me the pros, cons of it.. and also pros, cons.. of a shackle Lift? thankss!!
ctappan94 is offline
post #2 of 6 Old 09-24-2011, 10:50 PM
WoodyHD
1983 CJ7
I'd keep the shackle reverse. Moving the front shackles to be back makes the wheel go up and back when you hit a bump. Little bit smoother ride if my understanding is correct. I've heard that original setup may be better in some cases because the wheel being pushed forward can allow for more traction, but then you also have the chance of hitting your shackles which would cause you a new leaf spring. Never go over a 1" shackle lift (5" bolt hole to bolt hole). Most people will tell you to keep it to 1/2". Can't think of his name right now, but a guy on this forum has an excellent write up about steering and drive line.
WoodyHD is offline
post #3 of 6 Old 09-25-2011, 12:04 AM
adams1985cj
Shackle reversal was the best thing I ever did!! Rides smoother and the best thing it no longer wonders going down the road. As far as shackle lifts I have about an inch with a 2 1/2 suspension lift can't say I noticed anything negative, but there are people that hate them. To each his own I guess.
You donít buy it you build it!!
adams1985cj is offline
post #4 of 6 Old 09-25-2011, 12:15 AM
supersport126
Adams sir, What brand/model are you using for the reversal?
supersport126 is offline
post #5 of 6 Old 09-25-2011, 12:24 AM
adams1985cj
I used the rough country because it was the only no weld one I could find. I have had no problems it's been on for about a year now. Not to mention it's the lowest priced one too.
http://www.roughcountry.com/jeep_cj_..._reversal.html
post #6 of 6 Old 09-25-2011, 06:27 AM
gojeepin
1983 CJ7
I cover a lot of these issues in an article. The link is in my signature block.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
Updated shackle reversal with through frame shackle mojo_matic Jeep CJ Forum 1 06-10-2011 07:15 AM
Shackle Reversal or Front Shackle? ChefPatrick Jeep CJ Forum 5 05-11-2011 08:54 PM
Shackle Reversal jeff83 Jeep CJ Forum 4 04-25-2008 10:16 AM
Shackle Reversal SavSilvrCJ Jeep CJ Forum 2 02-03-2008 03:09 PM
Shackle reversal? boaman88 Jeep CJ Forum 5 12-22-2004 02:50 PM
