shackle problem - JeepForum.com
post #1 of 20 Old 01-29-2005, 05:31 PM Thread Starter
wilf
shackle problem
with a 4" pro comp lift why are my shckles folding back and touching my frame in the front? they are factory shackles. i can get them to fold back and stay.
wilf is offline
post #2 of 20 Old 01-29-2005, 09:51 PM Thread Starter
wilf
i can jack it up and cumalong the axle and straighten up the shackles but as soon as i let off they just fold right back. it was not like this until i took it out a couple of times. it seems as if the springs are to short from the rear hanger to front hanger. i will get some pics for you to see tomorrow.
wilf is offline
post #3 of 20 Old 01-29-2005, 10:23 PM
MudMonster
MudMonster's Avatar
yeah pics will definately help
"Don't be too proud of this technological terror you've constructed"
RED JEEP CLUB MEMBER #78
BIG GUNS AND JEEP OWNERS OF AMERICA CLUB MEMBER #3
Red Neck Jeep ClubMember#27Fire Engine Red '85 CJ-7, Howell FI-258, T-176, D300, 9", Warn Internal Hubs, Wagoneer front springs, RE Wrangler's in the rear, 33" TrXus', HEI conversion, Taurus fan, no emissions junk, and some 150w daylighters
MudMonster is offline
post #4 of 20 Old 02-08-2005, 04:21 PM
ollietonk
I had the exact same problem with the stock shackels on my ProComp lift. Mine were so bad I took pic's to the local 4Wheel Parts and they thought the springs might have been for a CJ5. The part #'s checked out and they recommended that I TRY a shackel reversal. I'm currently too poor for that so I replaced them with some heavy duty aftermarket shackels. They're about 1-3/8 longer and kept the springs from going over-center and smacking the frame. Adds a little lift, but nothing really noticable. So far they have worked great. Good luck
86' CJ7 (258 w/ Howell TBI, 33" ProComp MT's)
ollietonk is offline
post #5 of 20 Old 02-08-2005, 11:17 PM
Jeep Daddy
Jeep Daddy's Avatar
I saw the same think happen to a guy about a month ago. He has a 4" lift and looked like his shackles were a little longer and heavier duty than stock shackles. We were able to lift with a jack and it popped back. I don't know what to say except maybe the quality control at 4WD Parts (Pro Crap) isn't as good as it should be.
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #6 of 20 Old 02-09-2005, 07:00 PM
ollietonk
I'm hoping the longer shackels have taken care of the problem. Were the ones you saw on the trail or during daily driving. I haven't taken mine off road yet (still working out the bugs) and am curious if I have this to look forward to. It doesn't look like they could go over center the way they are now but it wouldn't surprise me. Just my luck
post #7 of 20 Old 02-09-2005, 07:17 PM
Jeep Daddy
Jeep Daddy's Avatar
Yes, it was on a pretty tough trail too. The longer shackle may take care of your problem. Lets hope it does.
Later
post #8 of 20 Old 02-09-2005, 08:24 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
While longer shackles might help, they arn't going to fix the problem. Your springs are too short(asuming your bushings and mounts are OK). You need to contact Pro Comp. It might be that they are rearcing their 2.5 or 3 inch spring packs to 4 inchs, causing them to shorten.
jeepdaddy2000 is offline
post #9 of 20 Old 04-04-2005, 10:10 AM
tankcj
tankcj's Avatar
My 4" pro-comp springs are doing the same thing!!!...It has happened twice now. I'll try the longer shackles too.
tankcj is offline
post #10 of 20 Old 04-04-2005, 10:26 AM
jeepskate
Anti-kickback shackles...Tomken makes them. Or you can buy boomerang rear shackles for a YJ, chop the spacer down 1/2" and run them upside down and backwards:
jeepskate is offline
post #11 of 20 Old 04-04-2005, 07:58 PM
ollietonk
Tankcj, PM on it's way
post #12 of 20 Old 04-05-2005, 05:38 PM
fromme
fromme's Avatar
1977 CJ7
How do you steer that thing?
"The Wicked Flee When No Man Pursueth, But The Righteous Are Bold As A Lion."
fromme is offline
post #13 of 20 Old 04-05-2005, 09:26 PM
jeepskate
I don't. In fact, the steering box is sitting on the floor right now because I decided to have the frame hot-dip galvanized. When it's back together it'll have hi-steer with Waggy linkage.
post #14 of 20 Old 04-05-2005, 10:34 PM
XxfirmanxX
I just put a 4" kit on mine no problems yet went with heavy duty shackles lookes good to me. Just for info sake pro comp leafs are actually made buy genuine suspention about $250 bucks cheaper for the kit your paying for the name.
79 CJ 7 CHEVY 350 glass body 35"s locked front & rear
94 Xj 4.0 Flowmaster 40 series Rustys 4.5 lift running on 32"s
04 FORD SUPERDUTY DEISEL POWER
XxfirmanxX is offline
post #15 of 20 Old 04-05-2005, 10:50 PM
jeepskate
Actually they are made in Canada by McCoy Bros. (they make springs for several companies). Pro-Comp & Genuine Suspension (and at least at one time RE Standard Duty) use the same springs from them, everyone else who uses them for the most part has springs made by them to their own specs. Genuine Suspension is 4 Wheel Parts Wholesalers 'house' brand.
Shackle Forward vs. Shackle Reversed rustymudder Jeep CJ Forum 37 07-12-2009 07:24 AM
big problem with shackle replacement HELP!! caleb7mm Jeep CJ Forum 19 05-23-2009 07:36 PM
Lift Springs/Shackle problem- pics 84MSRB Jeep CJ Forum 74 12-09-2008 08:14 AM
Shackle problem!! firejeep344 Jeep CJ Forum 4 09-03-2007 07:06 AM
Shackle and Shackle Bushing Blue83CJ7 Jeep CJ Forum 5 11-27-2006 05:06 PM
