Shackle lift question - JeepForum.com
post #1 of 6 Old 06-19-2013, 09:51 PM Thread Starter
ironbyron1
1977 CJ5
Is a shackle that claims to give a 2" lift actually 4" longer than stock shackles? I assume since the shackle is only on one end of the leaf springs that to achieve a 2" lift they would have to be 4" longer. Am I right about that?
Thanks!
Byron Oost
Owensboro, Kentucky
ironbyron1 is offline
post #2 of 6 Old 06-19-2013, 09:54 PM
lucdog
lucdog's Avatar
1980 CJ5
You are correct.
B
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #3 of 6 Old 06-19-2013, 10:24 PM
WSS
WSS's Avatar
1972 CJ5
X2......the axle is half way between the pivot point and the "lift", hence divide by 2.
WSS is offline
post #4 of 6 Old 06-20-2013, 09:46 AM
Renegade82
1982 CJ7
Yes, and that's about the limit you should go with shackles.... a good 3/8" welded shackle. But only if you beef up the mounts too. This is probably why the manf. only offer up to 2". Stock Jeep shackles are 3" hole to hole and stock wranglers are 4" hole to hole.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #5 of 6 Old 06-20-2013, 10:05 AM
2Xtreme
2Xtreme's Avatar
1979 CJ7
A 2" shackle lift will almost certainly mess with your caster.
I had 1.75" shackles at one point and the Jeep was not happy about it....
2Xtreme is offline
post #6 of 6 Old 06-20-2013, 10:44 AM
Renegade82
1982 CJ7
Yes, most likely it will, especially if theres a spring lift added. But shims will fix that issue. I used a ConFerr 1 3/8" shackle lift with 1 1/2" add-a-leafs with no problems for years but when I swapped out the add-a-leafs and stock springs for some 2 1/2" springs, then I had issues and needed to add shims.
