Shackle lift question - JeepForum.com
post #1 of 9 Old 06-23-2011, 08:39 PM Thread Starter
waller24
i am wanting to level my cj7 out. the front is about 2 inches lower from center fender than the rear center fender. I was thinking about doing the 1.75 front (rough country) shackles.
issue is i read in another forum that the stock shackle is 4 in from hole center to hole center. I just measured mine and it is 3 1/4 in from shackle center hole to center hole.
i just want to make sure i will be ordering the correct shackle lift height. Bc if stock is 4 then my lift will be .75 in higher than i need.
Any imput would be great. Thanks
waller24 is offline
post #2 of 9 Old 06-23-2011, 09:11 PM
Trapshooter
Welcome to the Jeep Forum. Tons of stuff here for you CJ7.
Stock shackles for your CJ7 where approximately 3 inches center to center from the factory.
I would double check to ensure you don't have something else going on, if the shackles all measure the same. Does your CJ actually look as though the back is higher than the front? Depending on where your are measuring there would be a difference between the front and back fenders.
Again.......Welcome to the CJ family.
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #3 of 9 Old 06-23-2011, 09:14 PM Thread Starter
waller24
ok i got a pm that stock is 3 in hole to hole
gonna try the 1.75 shackles and see
yeah i do have a bit of rake its a noticible nose down
waller24 is offline
post #4 of 9 Old 06-24-2011, 12:16 AM
L78THUMPER
2007 MK Compass
Get the springs rearched I wouldn't patch it by bigger shackles. Besides the bigger the shackle worse the ride
L78THUMPER is offline
post #5 of 9 Old 06-24-2011, 06:05 AM
twoleos617
if stock shackles were 3" and new ones are 4", that nets you 1/2" lift.....
most folks will tell you not to go over 3/4 - 1" of lift.
sounds like you have a spring or body mount issue and shackle lifting the front only could throw your steering off.
check you body mount brackets on the frame and the one at the nose as well.
you may want to investigate your actual problem a little more and proceed from there.
Welcome to the forum. we're here to help so ask away.
using the search feature will give more info than you could imagine too. lots of insitefull folks here.
got pics?
Torque is the measure of force that gets the cap off your beer.
Mike D.
twoleos617 is offline
post #6 of 9 Old 06-24-2011, 08:23 AM
duckbone
Add a leaf not a shackle.
duckbone is offline
post #7 of 9 Old 06-24-2011, 08:27 AM
Destr0
I would try and figure out where this rake comes from and remedy that. The CJ should sit pretty level from the factory so you have something going on (could be the PO put different springs in the back or a big heavy V-8 up front- something is either bringing the front down or rear end up).
Throwing on shackles may fix the rake but not the actual cause of the lean. If you determine the cause, then maybe shackles are a good way to fix it (if you have HD springs in the back and stock ones up front and do not want to spend the $$ on front springs), but until you figure that out, why put on a band-aid?
1994 Jeep YJ off road toy
1981 CJ7 SBC 350
2005 KJ Libertyt 4x4 CRD w/ 2.5" Frankenlift DD
Destr0 is offline
post #8 of 9 Old 06-24-2011, 08:28 AM
foggybottombob
Do not put lift shackles on the front of your Jeep. It will change your caster and you will not like it. Add a leaf if you want to lift the front a little cheaply.
foggybottombob is offline
post #9 of 9 Old 06-24-2011, 08:31 AM
Destr0
I have 3/4" lift (1 1/2" longer than stock) boomerang shackles on my YJ and the steering did not change dramatically (I would not go over 3/4" lift with shackles though). Is the CJ that different that a small shackle lift will make the steering that bad? Just asking because I was planning on putting some small shackles on my CJ during the build to help clear the 32s. I am thinking 4.5" center to center with a small boomerang shape (I have CNC plasma cutter so can make them any size/shape I want).
1981 CJ7 SBC 350
Destr0 is offline
lift , shackle
Shackle/Lift Question guitarfreak6688 Jeep CJ Forum 4 09-29-2010 09:43 PM
Lift-Shackle Question mmillen Jeep CJ Forum 29 01-04-2010 05:47 PM
Shackle Lift Height Question jeepguy85 Jeep CJ Forum 15 09-30-2009 10:21 AM
shackle lift question myzoo Jeep CJ Forum 9 05-20-2009 08:12 AM
Shackle Lift Question jscarce Jeep CJ Forum 1 03-16-2004 08:16 AM
