shackle lift problem - JeepForum.com
post #1 of 10 Old 01-02-2014, 03:29 PM Thread Starter
8u11y
1978 CJ7
firstly Hi, been meaning to sign up for ages....
My problem is I dont know where to bolt my rough country shackle lift to on the frame, I'm sure the instructions say to bolt it to the frame ( where the crossmember bracket bolts to) but this doesnt look at all right to me.
worst part is I didnt even want stupid lift shackles, the bloke sent me the wrong part and i couldnt be arsed to send them back to your side of the pond!
Thanks, Rob
8u11y is offline
post #2 of 10 Old 01-02-2014, 03:36 PM Thread Starter
8u11y
1978 CJ7
8u11y is offline
post #3 of 10 Old 01-02-2014, 03:37 PM Thread Starter
8u11y
1978 CJ7
Im assuming you use the existing hangars but the shackles seem to wide for this.
8u11y is offline
post #4 of 10 Old 01-02-2014, 03:45 PM
Manhattan
1981 CJ8
Yeah, you're missing the spring hangers. They bolt to the bottom of the frame, the shackles bolt to them.
1981 CJ8, Chevy 5.7, SM465, D300, RE 4.5, 35" BFG MTs, 20/30 4.56, Detroits, Warn 9500ti
Manhattan is offline
post #5 of 10 Old 01-02-2014, 03:47 PM Thread Starter
8u11y
1978 CJ7
cheers pal, i thought as much but the instructions are as much use as a chocolate fire guard! Thanks again
8u11y is offline
post #6 of 10 Old 01-02-2014, 03:58 PM
babytank31
1978 CJ5
I looks as if you bolted your shackles to the frame. You should have a set of spring hanger under your frame, that may be slightly smaller in width than the frame. There are many types of shackles available, but I think you have those on backwards. If the kit supplied a center crush sleeve, that is round and hollow to maintain proper shackle width, install your poly bushing followed by the center pin and slip the shackle over the spring eye. It should fit snug but not tight round the spring eye when it is torqued to manufacturers specs usually 25 to 35 ft lbs if my memory is correct. Don't mix up the shackle bushing with the spring bushings, some time thy may be different thicknesses.
babytank31 is offline
post #7 of 10 Old 01-02-2014, 04:10 PM Thread Starter
8u11y
1978 CJ7
I had to cut off the old hangars to repair the chassis (you can see what was left of the old tub in the background) I'll check tomorrow but I seem to think the shackles were way too wide for the hangar when i sized them up. Thanks for your advice mate, I will suss it out after Ive thrown some stuff round the garage and blamed all my tools..
8u11y is offline
post #8 of 10 Old 01-02-2014, 04:29 PM
CSP
It's pretty self-explanatory when you're removing old shackles and swapping in new ones. Honestly the instructions shouldn't have to tell you where they bolt on.
CSP is offline
post #9 of 10 Old 01-02-2014, 04:38 PM
lucdog
lucdog's Avatar
1980 CJ5
Don't forget the bushings need to be in the shackle hangers.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #10 of 10 Old 01-02-2014, 04:48 PM
babytank31
1978 CJ5
For what it is worth, do yourself two big favors. First use plenty of grease when installing bushings and second take your shackle and spring bolt to your local auto parts store and buy some quality, grease-able bolts. If you ever have to take it apart the bolt will be easy to get out. It also helps prolong bushing life.
