Shackle Lift - JeepForum.com
post #1 of 7 Old 06-12-2011, 08:02 PM Thread Starter
Brodie14
Shackle Lift
Let me start off by saying that I'm in no way, shape or form a gear head... but I'm learning, so any help is greatly appreciated.
I just bought an '84 CJ7 with a 3" lift. I'd like a little more lift and from looking around a shackle lift seems like a good option. My question is, will this change the angle of the drive shaft so much that I'll need to make modifications?
Again, I'm new at this so take it easy on me if this is an obvious question.
Thanks,
Brodie14 is offline
post #2 of 7 Old 06-12-2011, 08:51 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
I'll be nice & take it easy.
Lift shackles are the worst thing you can do to a CJ!
As a rule of thumb, No more than a 1/2" lift shackle.
There is a search function that will show many many answers to your question.
LT1CJ7 is offline
post #3 of 7 Old 06-12-2011, 08:57 PM
gojeepin
1983 CJ7
Yes... the longer shackles will change both your driveline and steering angles.
Read the article in my signature block. It covers many of the things you'll encounter.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #4 of 7 Old 06-13-2011, 12:36 AM
sanddrag
I must be the only one on the face of the planet with lift shackles and no real issues to report. Hrmm. I have 1.5" lift shackles and 2.5" Rancho springs and stock driveline and steering. The steering is a little light (not enough caster), but it's completely manageable, even at highway speeds.
sanddrag is offline
post #5 of 7 Old 06-13-2011, 03:25 AM
L78THUMPER
2007 MK Compass
Also the bigger the shackles the worse the ride besides everything else.
L78THUMPER is offline
post #6 of 7 Old 06-13-2011, 08:33 PM
RidgeRat
1980 CJ5
sanddrag, I don't notice a real problem either but I never go over about 55 mph and steering shaft/coupler/gear box are all tight so maybe that's why? I'm going to replace them but it's not a priority for me right now, maybe this winter.
1980 CJ5, Ford 289, T176, DANA 300, DANA 30, Ford 9", 35/10.50/R15 Super Swamper TSL
RidgeRat is offline
post #7 of 7 Old 06-13-2011, 08:51 PM
sanddrag
Yeah, I've been up to 75 or so without worry. It probably helps to have a swaybar, poly bushings, and relatively stiff springs and shocks.
sanddrag is offline
Getting rid of 1.5" shackle lift & helper springs - which lift to get now? 1984Laredo Jeep CJ Forum 11 08-01-2013 10:35 PM
Removing shackle lift, need spring lift. 2dswithaCJ5 Jeep CJ Forum 4 01-18-2010 01:50 PM
2in Shackle Lift ???? zachblamercj7 Jeep CJ Forum 11 07-27-2009 07:04 AM
shackle lift fireslider Jeep CJ Forum 2 07-06-2008 11:12 AM
Shackle Lift? bbrad Jeep CJ Forum 2 04-05-2007 09:28 AM
