Serp belt to v belt? - JeepForum.com
post #1 of 4 Old 01-10-2013, 05:03 PM Thread Starter
Lunchbox70
You read that correct, i am wondering if anyone has info on this. long story short, junked original 258 and picked up a 1990 258 and want to convert it to v belt.
main question, will the crank pulley from an older 258 ( v belt ) bolt right on to replace my serp pulley?
just want to keep things simple, only running water pump and alt.
no power steering, no ac, no smog pump and i plan to keep it this way for a while. so in my mind its would just be a hassle to have a serp belt.
thanks guys.
Lunchbox70 is offline
post #2 of 4 Old 01-10-2013, 08:05 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Lunch,
A quick Google search turned up mixed information, for me.
But, the consensus was the serp 258's crank nose is shorter than the v-belt version, and that v-belts will not work on the serp crank.
Also, I believe the serp 258's water pump was a reverse direction, no? I'm not sure how that would work with the v-belt setup.
Hope this helps, or at least bumps your question to someone who knows for sure.
Matt
Matt1981CJ7 is online now
post #3 of 4 Old 01-10-2013, 08:11 PM
fourbtgait
1930 MK Patriot
Originally Posted by Matt1981CJ7
Lunch,
Matt
Matt,
You are correct about the water pump, would need to buy opposite direction flow for a fact.
Not sure about crank nose, though I can see it.
fourbtgait is offline
post #4 of 4 Old 01-10-2013, 08:40 PM
5-90
5-90's Avatar
1988 XJ Cherokee
thanks guys.
1) There's nothing wrong with a snake belt - it usually lasts a bit longer anyhow.
2) Don't forget to change your water pump - you'll be spinning it the other way, if you change.
There may or may not be a difference in length for the crank snout between the two - so watch out. It's probably not anything that can't be handled easily, but it is a potential pitfall...
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
258 , 4.0 , belt , cj7
