sequence and torque specs for 1986 258 PLEASE! - JeepForum.com
post #1 of 3 Old 10-21-2006, 05:53 PM Thread Starter
rkutzner
rkutzner's Avatar
I am replacing a head gasket for a freinds 86 CJ7 and she is going to be out of town for a couple weeks and the service manual is in her house. I got it apart and all cleaned up, just stuck without the specs and sequence for the head bolts (I removed the head with the intake and exhaust intact)
2001 TJ Sport
Everything SELF INSTALLED.
The Serious Stuff:4.5 RE LA, 35" MT/Rs, 4.88s, Super44 w/Detroit, D30 w/Ptrax, SYE, Tera 4:1, 2LOW & Rear Disks, AntiRock, Lotsa Skids (some homemade!), Nth Shock Shifters, Patriot 9500...and LOTS more !
rkutzner is offline
post #2 of 3 Old 10-21-2006, 06:48 PM
gosupes
Googled it.
I normally go 30% torque on the first pass, 60% on the second, the 100% on the last pass. #11 doesn't get as much torque as the rest due to a water jacket. If you have the 1/2" bolts, all except #11 are 110 lbs. #11 is 100 lbs. For the 7/16" bolts, all get 85lbs and #11 gets 75lbs.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
post #3 of 3 Old 10-22-2006, 05:06 AM Thread Starter
rkutzner
rkutzner's Avatar
Cool, a clockwise circle spirally outward starting at noon looking from the drivers side
I had her buy new ARP bolts and I opened up the box and they give their own torque specs for their bolts, depending on if you use their bolt lube or regular 30W oil. It's like around 70 with their lube and 110-135 (dang age, forgot what I read already!) with the oil. They do say use the factory torque sequence so THANKS
What term did you google? I tried a few different ones and couldn't find anything....guess I need training....
2001 TJ Sport
rkutzner is offline
Torque Specs for 258 81cj7id Jeep CJ Forum 2 04-13-2009 06:44 PM
Torque specs 79CivilianJeep7 Jeep CJ Forum 3 12-08-2006 12:41 PM
torque specs txfireplug Jeep CJ Forum 0 10-07-2004 06:22 PM
Torque specs. JERSEYJOE Jeep CJ Forum 2 04-05-2004 08:38 AM
1986 CJ-7 stock specs? blue4banger Jeep CJ Forum 1 02-22-2003 07:00 AM
