Separating Engine From Tranny, Then Rebuilding... - JeepForum.com
post #1 of 4 Old 01-09-2010, 09:17 PM Thread Starter
poppatello
Well I finally got my truck running. The 258 I got for free is in the back of it and I wan to take it to the shop and pull it out. The 258 still has the TF 999 attach to it. My question is will I get any oil when I separate the tranny from the engine?
Once I separate I will mount the engine to the stand. What should I do then? Should I do a compression test or just tear it down? I was thinking of doing a compression test and replacing the heads with a 4.0 one. I was also thinking of making the 258 a 4.6 which would have to be torn down and re-bored. What do you guys think? The motor was rebuilt before by a company I think in Canada. There is a sticker on the motor and its doesn't look like it's been used much. The guy pulled it to drop a 5.0 in his jeep and said it ran great. I don't mind taking the time and money to do it right so any advise would be great...
In a world full of copy cats, be an original...
Paved Roads
A Fine Example of Needless Government Spending
Originally Posted by berserker View Post
Sometimes it a good idea to pull a vacuum hose before the wife rides in it--you can tell her you need a new ____ and once you get your new ____ you can reconnect the hose. :)
84 Cj 7 w/ 4-Banger, 4.5" BDS lift, 1/2 Trans Drop, Twin Stick, 32" Tire, Front Aussie Locker, No Sound System Yet, No Armor, Warn 8274 Not Installed, Webber Carb Upgrade, Luckycheese Ing. Upgrade...
poppatello is offline
post #2 of 4 Old 01-09-2010, 10:01 PM
texasimport
1978 CJ5
no fluids will/should leak when you take the trannie off the bellhousing.
78 304-CJ5
texasimport is offline
post #3 of 4 Old 01-09-2010, 10:19 PM
VACJ7
VACJ7's Avatar
There is probably still transmission fluid in the torque converter so just make sure it does not drop out. The ATSG manual says to attached a small c-clamp to the bell housing after you slide the transmission back to hold the torque converter from falling out.
I will be pulling my TF999 in a few weeks.
VACJ7 is offline
post #4 of 4 Old 01-10-2010, 09:39 AM
texasimport
1978 CJ5
my bad. . I did not realize your with automatic. Never could get my arms around automatic for most applications.
78 304-CJ5
Separating the D18 from the T90- help! Bren Gun Jeep CJ Forum 4 11-24-2009 11:49 AM
Rebuilding engine genghisman Jeep CJ Forum 8 05-15-2009 08:27 AM
Rebuilding Engine - What's biggest bang for the buck?? qwert98 Jeep CJ Forum 7 05-25-2007 08:23 PM
separating hubs advice molsenice Jeep CJ Forum 7 01-24-2007 10:55 AM
separating steering shaft from box thebeast77 Jeep CJ Forum 3 06-27-2006 08:09 PM
