Sense wire for 12si alternator - JeepForum.com
post #1 of 22 Old 06-09-2012, 03:50 PM Thread Starter
TadaoBaba
Hi there, searching hasn't found the exact answer I am looking for. I am replacing my alternator (with a Powermaster 47294), and have read JeepHammer's explanations that the alternator sense wire is better connected somewhere downstream, rather than back to the BATT lug on the alternator. I've got an 80 CJ5, and I am looking for a good place to run this wire. I've upgraded most of the charging wires, added the requisite extra grounds, and have my headlights, electric fans etc. running off relays.
Where is a good location to run the sense wire, exactly? Is the starter solenoid not far enough away? How about running to the positive battery terminal? I'm looking for some specific ideas, other than just "down stream."
TadaoBaba is offline
post #2 of 22 Old 06-09-2012, 06:48 PM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
bump....me too
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
post #3 of 22 Old 06-09-2012, 06:57 PM
parker007
1977 CJ5
why not just put in 1 wire regulator and just run 1 wire to batery they cost maybee 15 dollars, i belive the wire you talk about originaly went to either ignition switch or charge light.
parker007 is offline
post #4 of 22 Old 06-09-2012, 07:22 PM Thread Starter
TadaoBaba
1 wire has been thoroughly been covered as being the weak way to go. Hard on alternators and electrical systems.
post #5 of 22 Old 06-09-2012, 07:52 PM
lucdog
lucdog's Avatar
1980 CJ5
Agree on the light of ignition. I've been running mine on the ignition for half of last summer. And the last 2 months (trail only keep)
I seem to remember on the 1 wire, JeepHammer stated, the only drawback to the 1 wire was that in can draw down the battery over a period of time when not used. I don't remember anything about hard on the alternator, or other electrical. I wasn't that long ago.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #6 of 22 Old 06-09-2012, 08:03 PM Thread Starter
TadaoBaba
Yeah - I'm not looking for one wire info, though. Want to do it three wire, with an excite (stock) and a sense.
post #7 of 22 Old 06-09-2012, 08:07 PM
lucdog
lucdog's Avatar
1980 CJ5
I realize that, you brought it up in your post before mine. And your info wasn't correct.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #8 of 22 Old 06-09-2012, 08:21 PM
lucdog
lucdog's Avatar
1980 CJ5
The postive Lug on the battery or the battery side of the solenoid would be the only place down stream I can think of. Since the battery connection on the alternator always has 12 volts, and since it's connected to the hot side of the solenoid, and the sense wire is the same gauge . What I mentioned above is the only logical choice as I see it.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #9 of 22 Old 06-11-2012, 01:40 AM
hutch1200
hutch1200's Avatar
1979 CJ7
I sent J-Hammer a PM 2 days ago to see if he was OK. No word. Hope & pray all is well. Anybody nearby to check on him? Should be a thread?
post #10 of 22 Old 06-11-2012, 02:09 AM
BagusJeep
1981 CJ7
He cruised past yesterday but has not posted for near a month.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #11 of 22 Old 06-11-2012, 05:20 AM
jay-h
The main purpose for the sense wire is so that the battery gets proper voltage, so I would put it there. Normally (unless your wiring is bad) battery is pretty close to alternator voltage, but sometimes not.. For example if you are using a solid state battery isolator for two batteries, there is a voltage drop and the sensor wire should be on the downstream side.
jay-h is offline
post #12 of 22 Old 06-11-2012, 06:24 AM
bentshackle
1983 CJ7
I originally wired mine into the feed to the horn relay, per JH's instructions.
Then I had a not so insignificant parasitic drain from my alt with the key off. I probably just need a new regulator but I changed it to sense off of a switched feed on the back of my fuse block instead. I get 14.8V at idle with everything electrical on.
Figured it only needs to sense with the ignition on so why does it need a constant feed? Sorry I can't remember which circuit and I'm not at home to go find it. I just get back in there with a test light and found one that fit my criteria.
bentshackle is offline
post #13 of 22 Old 06-11-2012, 06:34 AM
John Strenk
John Strenk's Avatar
1976 CJ5
On some jeeps the sense wire connects to the (+) on the ignition coil. Probably to make sure the power to the coil has the proper electrical voltage at all times. Some go to a junction just off the ignition switch. Some travel am inch to the output post on the alternator.
If you put it on your battery then the battery will be OK but you can have a big drop in power going to your electronics and your jeep won't run right and you will waste money slowly in gas costs.
If you put it on your electronics the the battery can get over charged and you will have to buy new batteries more often.
John Strenk is online now
post #14 of 22 Old 06-11-2012, 07:31 PM
flashpointmax
Help me out with an understanding of why this would be the case. After the engine starts the voltage going to the primary of the coil is normally reduced down to around seven or eight volts because it's fed through a resistive wire. IMO I'd think any potential above that level would be sufficient and not impact the firing system.
flashpointmax is offline
post #15 of 22 Old 06-11-2012, 07:32 PM
jay-h
While this is true, then you're treating the symptom. Ideally the battery should be getting the correct voltage (so it doesn't overcharge). If the circuitry has excess voltage drop, that should be addressed as a primary issue. Otherwise you're putting bandaids on the problem.
jay-h is offline
alternator , wiring alternator plug
12si rebuild petey156 Jeep CJ Forum 4 12-13-2009 10:55 PM
Alternator 2-wire plug has only 1 wire. What's missing? monninen Jeep CJ Forum 6 08-30-2009 10:00 PM
12si in '74 258 stock bracket. Jeephammer? kpauley Jeep CJ Forum 7 08-23-2009 02:59 PM
Wire an alternator? JOKER4INK Jeep CJ Forum 2 07-23-2006 01:05 PM
alternator wire dmproske Jeep CJ Forum 1 05-13-2005 06:30 PM
