Sending Unit/Idle Help - Page 2 - JeepForum.com
post #16 of 20 Old 06-10-2013, 06:20 AM Thread Starter
SalParadise17
1979 CJ7
I adjusted the float when I was putting everything back together, and it should be correct if not a little rich.
Bagus, I do not have the Power brake booster, and the Venuris are nice and clean. When I get home I will Cap off all the lines except the Distributor and see what happens.
I'm having trouble assessing the timing and adjusting the idle/air mixture, because I can never get the jeep running long enough and consistently enough to make adjustments or check the timing.
I'm sure there is something I am missing (Weber 38 or MC2100) that will make my life easier. Thanks for your help and any future suggestions are appreciated.
SalParadise17 is offline
post #17 of 20 Old 06-10-2013, 06:20 AM
robs7
1983 CJ7
Originally Posted by SalParadise17
Hey guys,
So I spent the last couple days rebuilding the carburetor and put it back on this morning. There was about a 1/4" of crud in the bottom of the float bowl.
After installing the carb I seem to be having the same type of problem. The jeep starts up and runs for about 2-3 minutes and then stalls out. Now instead of running at 1200 rpm it is running at about 200 rpm and I can't seem to get the idle to go up.
I'm about at the end of my rope and I really need an Ah-ha moment so any help would be greatly appreciated.
What happens when you give it a little gas? Does it die or rev nicely? Do you have a choke? Do you smell gas while the engine is idling? I'm just wondering if maybe its getting too much fuel. Just a thought. Rob
robs7 is offline
post #18 of 20 Old 06-10-2013, 06:24 AM Thread Starter
SalParadise17
1979 CJ7
The engine revs nicely. I have an electric choke that I've toyed with but to no avail.
Would my idle be down around 2/300 if I was getting to much fuel? There is a smell of gas while idling.
post #19 of 20 Old 06-10-2013, 07:31 AM
robs7
1983 CJ7
You could be flooding it a little. I would recheck you idle mixture and your choke setup. I don't have your carb so I can't give you exact directions however, on my carb, I turn the idle mixture screw all the way in and then back it out 2-1/2 turns for a starting point of adjustment. If you smell fuel like you say then I bet you have it too rich. This would make it idle rough because you are not getting enough air mixed with the fuel until you step on the gas which opens the butterfly up. I would also go through that choke again. Rob
robs7 is offline
post #20 of 20 Old 06-10-2013, 01:42 PM
86cj74.2L
86cj74.2L's Avatar
Hey guys,
Have you cleaned out the Venturi cluster brass tubes? If you had sediment in your float bowl its in other places inside the carb as well
86cj74.2L is offline
fuel filter , fuel lines , idle , sending unit
