Seen any Asinine Repairs lately? - Page 2 - JeepForum.com
post #16 of 27 Old 09-07-2011, 10:14 AM
ejeeperguy
1982 CJ7
JeepHammer ,
The proper term is "smack the stupid out of them!!!". You can go ahead and use it.
ejeeperguy is offline
post #17 of 27 Old 09-07-2011, 10:22 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Originally Posted by JeepHammer View Post
Plastic 'Zip' ties holding a tie rod together, keeping the socket on the ball...
Wait! you can't do that? ohhhhh... I remember a certain Fiat X-19 I drove 200 miles home like that once.... But I backed the wire ties up with bailing wire...
John Strenk is offline
post #18 of 27 Old 09-07-2011, 10:30 AM
arkiemurph
Whew, 22 mag, that could've gone wrong, huh? Gives me the willies, too.
M
Love thy neighbor, but don't mow down the hedge.
arkiemurph is offline
post #19 of 27 Old 09-07-2011, 10:34 AM
82KansasCJ
82KansasCJ's Avatar
1982 CJ7
I've found too many "live" wires in my jeep hanging or hidden in the looms with nothing else covering them.....got a little "sparky" at times
1982 CJ-7....not perfect but still alot of fun!
82KansasCJ is offline
post #20 of 27 Old 09-07-2011, 10:38 AM
g4x4xgeoff
bondo filled inside the frame to make the paper thin frame appear/feel strong.
great way to screw over a buyer. ask me how i know.
Originally Posted by Hurley91 View Post
I could be drunk, high, raped and almost dead.... and I could still recognize it.
g4x4xgeoff is offline
post #21 of 27 Old 09-07-2011, 02:23 PM
Tigerjeep79
1979 CJ7
The dash is my pet peeve, 'cause you look at it all the time. I've seen some awful butchery on Jeeps. The P.O. of my CJ installed a cheapo aftermarket radio, and it looks like he cut the hole out with an axe!
Oh, and I've seen a 2x4 used as a front bumper. I got a chuckle out of that one.
Tigerjeep79 is offline
post #22 of 27 Old 09-07-2011, 02:27 PM
DT5150
1983 CJ7
my whole jeep has been one asenine repair job after another. bumper to bumper.. literally.
SOLD! 83 CJ-7. TBI Small Block Chevy 350/TH350/D300, Scout II Dana 44 front, CJ Dana 44 rear. 4" BDS Lift with 35's. Currently Jeepless.
DT5150 is offline
post #23 of 27 Old 09-08-2011, 03:44 PM Thread Starter
Mortimer77
1977 CJ5
I'm not trying to be nasty, but I've seen one driving around here that has a huge board attached to the bumper (or maybe it is the bumper? It's hard to tell).
It looks ridiculous.
Mortimer77 is offline
post #24 of 27 Old 09-08-2011, 05:01 PM
zapp1
2012 WK
Well, the list is long but here are a few things...
cut the dash up to put speakers and radio in,
replaced the rear floorboard with a replacement piece, right on top of the old rusted one
yes there was duct tape and spray foam used to let it pass inspection
Can't complain though, the jeep was free, doing a frame up restoration on it, so this time around, no spray foam
zapp1 is offline
post #25 of 27 Old 09-08-2011, 07:47 PM
BagusJeep
1981 CJ7
Paper clip holding on the top seat belt mount. String holding the bottom of the belt on to the roll bar. Not a huge worry as the buckle was broken anyway so it did not affect overall system performance. My brother in law justified it as seat belts are only for show so the cops do not give you a ticket, we travel so slowly here that seat belts are really unncessary. I sit in the back of his car as I do not trust his seat belts.
Toyota master cylinder and servo. Now that seems OK as they were properly made parts from a reputable manufacturer. Jeep parts are hard to get here so the mechanics use anything cheap and to hand. However brakes locked very easily and there are several palm trees on the highway with turning skid marks leading towards them.
Oil change sticker/ label hanging on the dashboard. Supposedly to denote when your next oil change is due it suggests they actually changed your oil and filter. I have had an oil pressure light come on on a Peugeot with an internal oil filter that had regularly oil changes, they never changed the filter. External filters I have seen ignored or polished with a cloth, I now mark the filter and if not changed I reach into my cupboard and pull one out and do it myself. I also check the oil when it comes back to make sure it is clean.
Axle nut loose, they had put a nail through the castenated nut but not tightened it. as it is a 1 5/16" or 34mm nut it is a large one so I could only figure they forgot the 150 ftlb torquing or did not have a socket large enough.
The bottom of the windshield frame / cowl seal were completely eroded. A piece of PVC black sticker applied 1.2" wide across the whole area to make it look like a seal. I did this and it actually looked quite good until I coudl locate the right parts.
Sticker on the side of the hood - real big and sexy for "ARB Air Locker - locking difeerental" Yes, misspelled and it did not have an Air Locker. I would have kept it but the spelling bugged me.
The block of wood that stops the drivers seat from going too far back. One of mine, I am still struggling to open up the seat recline mechanism to fix it.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #26 of 27 Old 09-08-2011, 09:41 PM
gpower77
Test driving a jeep and started smelling something burning under the hood, then suddenly a lot of racket, sounded like and exhaust leak. Pulled over and looked under the hood and the exhaust manifold air injection tubes had rusted out about 2 inches above each fitting, the guy had put rubber vacuum lines and plastic tees for each one, hooking it back up to the air pump. What a riot, then you really start looking the jeep over!
gpower77 is offline
post #27 of 27 Old 09-09-2011, 12:59 AM
BagusJeep
1981 CJ7
A toyota radiator in a CJ. Not a big old one but a smaller saloon car one. Overheated.
Dash Pad Repairs MoC Jeep CJ Forum 2 05-25-2010 07:59 PM
auto body repairs nichboy Jeep CJ Forum 6 05-21-2010 07:21 AM
83 CJ7 - more repairs Throbbin Rods Jeep CJ Forum 1 12-12-2009 07:20 PM
Worthwhile repairs to look for in a CJ? Ken4444 Jeep CJ Forum 20 12-05-2009 09:24 AM
Repairs for a soft top csistrunk Jeep CJ Forum 2 10-19-2002 01:20 PM
