Seatbelts attached to fold/tumble seat instead of floor - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Seatbelts attached to fold/tumble seat instead of floor
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WDROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail
Unread 05-23-2013, 07:22 PM   #1
CJKevin1978
My new-to-me CJ-7 can with all Bestop seats but only one rear seat belt. I have a fam of 4 so I bought a pair of belts. But I am thinking of attaching them to the seat if there is a solid point for them. So, have any of you done this? I'd like to have a clean, smooth "bed" when the seat if folded.
I can see how this may be a little less safe than the belts on the floor/tub. But it seems to me that it would require a very unlikely series of events to cause that seat to release in a crash. I am more concerned about mounting points that are dependable/strong.
CJKevin1978 is offline   Reply With Quote Quick reply to this message
Unread 05-23-2013, 07:37 PM   #2
LeePrather
1978 CJ5
I just finished installing a bestop fold up rear seat for my kids. I installed 2 seatbelts. There should already be 2 holes in the back of the floorboard. I anchored to them with 7/16 grade 8 bolts and a seatbelt nut on the bottom. I also had to drill a hole in the middle of the back in order to install the locking mechanism and I anchored the catches using the same setup. Pretty sure it ain't going anywhere...
LeePrather is offline   Reply With Quote Quick reply to this message
Unread 05-23-2013, 08:50 PM   #3
LumpyGrits
Mount to the floor is the best.
That is how AMC did it.
This is NOT the place to take short-cuts
LG
LumpyGrits is offline   Reply With Quote Quick reply to this message
Unread 05-23-2013, 10:06 PM   #4
Ivehad4
1978 CJ7
I wouldn't trust that one little folding latch that holds the seat down in an accident. If the seat folds up it really doesn't matter if the occupant has the belt on or not - it could ruin their day. Bolt em to the floor.
1978 CJ7 304/T150
1959 Willys CJ5 F4/T90
1995 XJ 4.0
1998 TJ 4.0
Ivehad4 is offline   Reply With Quote Quick reply to this message
Unread 05-24-2013, 07:34 AM   #5
keith460
Jeep. There's Only One
keith460's Avatar
Not a good idea to bolt the seat belts to the seat frame and hoping the single latch will hold in place in the event of a unforeseen accident. Bolt them to the floor using grade 8, fine thread hardware.
I have the same type of rear seat and bought two rear set belts and also had to drill an addtional hole in the floor for another anchor bolt. The rear floor only has three threaded 7/16-20 holes and the center one in the middle is doubled up for seat belt anchoring. The additional hole I had to drill was for the latch bracket that is normally held in place with three holes but I cut off one since I doubled up on the seat belt anchoring. The bracket comes with three holes, one for mounting and one each for the seat belt anchor which also bolts the bracket down.
Here's my setup:
The hardware used is S.S. grade 8 shoulder bolts that are 7/16-20 thread. Very hard to find to say the least and I believe I acquired them from TotallyStainless.com
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums...d.php?t=434226
keith460 is offline   Reply With Quote Quick reply to this message
Unread 05-24-2013, 07:46 AM   #6
LeePrather
1978 CJ5
Here's my setup:
Exactly how I have mine as well...
Unread 05-24-2013, 07:52 AM   #7
frhrwa
Fish'n Fool
frhrwa's Avatar
ditto to Keith460, that's the way it should be.. unless you want the person in the back to do and ejection WITH seat attached if you hit something.. better to bolt those belts down so you keep your seat.. ha ... and the passenger....
I want to die in my sleep like my grandfather, not screaming in terror like the passengers in his JEEP!...
frhrwa is offline   Reply With Quote Quick reply to this message
Unread 05-24-2013, 07:51 PM   #8
Trombino
1978 CJ7
With regards to the 7/16-20 grade 8 bolts, the only place I was able to find them was my local small-town hardware store. The best I could do at orange and blue was grade 5. I actually just stopped tonight and picked up some for the front seat-belt mounts.
'78 CJ7 -- Chevy 350 SBC, Holley 4-BBL, TH700R4, B&M Performance Shifter, Dana 300 w/ Twin Sticks, 3" Shackle Lift, 3" Body Lift, D30 Front (Disc), AMC 20 Rear w/ Moser 1-Piece, 4.10's, 35x12.50/15 General Grabber MT's, Cragar Soft 8's (15x8 w/ 4" BS)
Trombino is offline   Reply With Quote Quick reply to this message
Unread 05-24-2013, 08:38 PM   #9
LeePrather
1978 CJ5
I spend more time and money in the hardware store than on auto parts for my jeep...lol
Unread 05-24-2013, 10:43 PM   #10
WSS
1972 CJ5
This one is tied to the cage, seats and seatbelts/harnesses. The cage was built as a "family cage", so it is designed to keep my family safe. CJ tubs are not attached all that well so i decided to go the extra and build a new cage with the A and C pillar tied along with the seats tied to the cage. The rear seat is a fold and tumble bestop trailmax II. I redid the front mount to use larger hardware and thicker pivot mounts but the back uses the tumble latch.
WSS is offline   Reply With Quote Quick reply to this message
Unread 05-25-2013, 07:02 AM   #11
thompsoj22
wow that's a cage!
i think that is the type design where everyone climbs out/ walks away from unbelieveable destruction. you will hopefully never need it to do it's job. as the old saying go's, better to have one and not need it than to need it and not have it.
thompsoj22 is offline   Reply With Quote Quick reply to this message
Unread 05-25-2013, 11:34 AM   #12
WSS
1972 CJ5
Thanks! That was my hope, I went with the "Luck favors the prepared" idea. In the research phase, I found the capsule type had better results after the fact and tying the cage into the frame was a must. It is best to have the seat tied to what ever the seatbelt is tied too. In other words, if the seat is bolted to the tub then the belts should be too and not the roll bar or frame in case of separation, then you have a compression situation! Not good.
