Seatbelt/Hardtop/Roll Bar Bushings on a CJ8... - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Seatbelt/Hardtop/Roll Bar Bushings on a CJ8...
Poison Spyder DeFenders™ - "Tubeless" Jeep FendeBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 12-29-2008, 05:51 PM   #1
MtNittany
1985 CJ8
...I have exposed threads from the seatbelt bolts and need to install bushings between the back of the cab and the roll bar. My guess is the gap is about 3/4".
I've seen rubber bushings everywhere, but I'm very hesitant to use them because I don't think they'll weather well and I think they'll drip black goo down my paint job.
My first choice would be nylon, but I can't seem to find any anywhere. Anyone have rubber bushings installed? Any problems? Any source for some good nylon bushings? Any alternative I'm overlooking?
Thanks in advance...
MtNittany is offline   Reply With Quote
Unread 12-29-2008, 05:53 PM   #2
jscherb
When I had a half-hardtop on my Scrambler, I used shock bushings, the kind that go on the stud-end of shocks. One inside the cab and one outside. There wasn't a problem with weathering, but I suppose you could use poly shock bushings if you didn't want to use rubber.
jscherb is offline   Reply With Quote
