Seat height?? - JeepForum.com
post #1 of 13 Old 01-01-2014, 05:29 PM Thread Starter
brendangsxr
1975 CJ5
Seat height??
HI everyone
I robbed the seats out of my old ego tracker and made some brackets. When I look through the windshield I have to lean forward and look up to see street lights. Can anyone go out and measure the stock seat height for a 75 cj5??
From the floor of the tub to the top of the bottom foam where your butt goes.
Thanks
brendangsxr is offline
post #2 of 13 Old 01-01-2014, 05:39 PM
bptactical
Better yet prop the seat up on blocks and let your body tell you what optimum height is.
Play with angle and side-side placement as well.
You have to fab brackets anyway, make em what works best.
You will be surprised what an inch here and there will do.
bptactical is offline
post #3 of 13 Old 01-01-2014, 06:58 PM Thread Starter
brendangsxr
1975 CJ5
Well that's what I did originally and I seem to be way off! I need a ball park figure to go off of. To get my belly button at the bottom of the steering wheel the drivers seat needs to come down 5 inches. I'm just not sure how these seats were in these things originally to know where I should be placed in the vehicle.
post #4 of 13 Old 01-01-2014, 07:54 PM
Spieg8
1984 CJ8
^^Agree with this^^
Use some 1x4 pieces of wood and stack them under the seat bracket until you find what feels best. Then fab something to the same size.
Spieg8 is offline
post #5 of 13 Old 01-03-2014, 07:54 AM
Throbbin Rods
1976 CJ5
As a starting point, I have 10.5" from the floor pan to the bottom of the cushion. Maybe mock something up at that height and then work from there. If it helps, I am 6'0" and 220 lbs. I am looking to move my seat back about 6 inches, cut into the wheel well, etc but not in these jeezly freezing cold temps. Supposed to be -20 to -26 tonight.
Let me know if you need anything else measured.
Bill
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming—Wow…What a Ride!
Throbbin Rods is offline
post #6 of 13 Old 01-03-2014, 01:36 PM
agear
Original poster - youre sitting too high arent you. Also, do you have sliders ? Would that help ?
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #7 of 13 Old 01-03-2014, 03:59 PM Thread Starter
brendangsxr
1975 CJ5
Yes I am sitting too high and yes I do have sliders.
post #8 of 13 Old 01-03-2014, 05:32 PM
Nereussailor
I sit like that in my Jeep every time I drive it and I have stock seats and brackets. I'm 6'1" tall and have the seat back as far as I can go.
I'm not sure what tomorrow will bring, but it can't be any worse than what I've already been through.
Nereussailor is offline
post #9 of 13 Old 01-03-2014, 05:41 PM Thread Starter
brendangsxr
1975 CJ5
Well it was hurting my neck so I'm doing something about it! Lol. I'm dropping them about 2"
post #10 of 13 Old 01-03-2014, 06:27 PM
Spieg8
1984 CJ8
Just be sure you don't end up with your knees higher than your shoulders...
Spieg8 is offline
post #11 of 13 Old 01-03-2014, 06:39 PM Thread Starter
brendangsxr
1975 CJ5
Believe me I thought of that! Lol. I called a friend that use to have a 5 he said he had about 7 in b/w the seat tnd the steering wheel to squeeze his legs into. That should put these seats right about at that mark! I figure I can tweak from there!
post #12 of 13 Old 01-03-2014, 08:55 PM Thread Starter
brendangsxr
1975 CJ5
2inches seems to be right on the money!
post #13 of 13 Old 01-04-2014, 09:54 AM
ScroungerLee
If for some reason you decide to take out the sliders I am in the market for one.
ScroungerLee is offline
