Quantcast Seat Brackets for 1974 CJ5 - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep CJ Forum > Seat Brackets for 1974 CJ5
Old 05-07-2009, 12:20 PM   #1
Monkeybone
1964 CJ6
This is my first restoration and the hardest part for me to find is the seat brackets/mounts/track/riser, whatever you want to call them. Everytime it seems that I am getting close there is nothing. They all seem to stop at 75 ot 76. Any suggestions? Should I just get one for a 76 and modify so it is able to bolt into the floor? Thanks in advance.
Monkeybone is offline   Reply With Quote
Old 05-08-2009, 12:44 PM   #2
Monkeybone
1964 CJ6
or even just pictures?
Old 05-08-2009, 12:47 PM   #3
hugedodge2000
1982 CJ7
they are called sliders......you can get universal ones off ebay. Hope that helps :-)
hugedodge2000 is offline   Reply With Quote
Old 05-08-2009, 12:51 PM   #4
incynr8
1974 CJ5
Bench or lowback seats?
I'd assume almost 99% of them by 74 were split lowbacks. The passenger side flips/folds forward. You will only find these used, both the brackets and the seats. The original seat cover style is also not reproduced.
I can take pics tonight if someone else doesn't post them, my Jeep is in the alignment rack shop now, hoping to pick her up after work.
incynr8 is offline   Reply With Quote
Old 05-08-2009, 01:02 PM   #5
CSP
They aren't sliders.
You won't be able to use '76 and up mounts as the floor isn't even close.
The best bet is to put a wanted ad on any and all CJ forums on the web. If you're not doing a true restoration they aren't that hard to fabricate using steel tubing.
CSP is offline   Reply With Quote
Old 05-08-2009, 01:22 PM   #6
incynr8
1974 CJ5
on my 1974, the driver's seat only can slide a trivial amount before the back strikes the rear wheel well, and the driver seat brackets bolt into various positions for skinny, skinnier, and skinniest drivers. So that side only does have 'sliders'.
The passenger side is a static mount that bolts in and is simply a front pivot function, with a rear O shaped bolt that the hook attaches to, a front pull ring or directly from the rear (for a seated passenger) can unhook that and fold the seat, then flip it to get out.
Alignment shop says my 74 is done and I will strive to at least take phone pics tonight if no-one else posts the -75 arrangement. Unfort my bolsters need some help, so I have to get that attended to later.
I might have a lead on a 74 being parted. I'll ask....I know i need the U shaped rear seat holddown brackets, easy to fab I know, but I also want original bits and pieces.
Old 05-08-2009, 01:28 PM   #7
CSP
Yes the drivers side has a slider, but that isn't the mount part in question I believe nor will a universal slider accomplish the needed task here. That was my point.
Old 05-08-2009, 01:33 PM   #8
incynr8
1974 CJ5
yes agreed. a simple slider track on the floor would make for an unhappy experience!
Old 05-08-2009, 01:40 PM   #9
Monkeybone
1964 CJ6
thanks guys!
Old 05-08-2009, 05:14 PM   #10
xeroOTG
1975 CJ5
It should be identical to a 75. I have a 74 and a 75. There isn't much that's not interchangeable between the two.
My jeep gives a whole new meaning to the phrase, Just Empties Every Pocket!
1975 Jeep CJ5 258 TBI EFI, T-18, D-20, D44 rear, 4.11.
1992 Jeep Cherokee 4.0L, AW4, NP231 <- new addition to my family October 09'
xeroOTG is offline   Reply With Quote
Old 05-08-2009, 09:55 PM   #11
CSP
Just to open up the possibilites, the same brackets were used from 55-75.
Glock Forum
