Searching for the golden tuning - Page 5 - JeepForum.com
post #61 of 684 Old 08-07-2012, 12:14 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Dada,
You may find this thread interesting....
Matt
Matt1981CJ7 is offline
post #62 of 684 Old 08-07-2012, 01:04 PM Thread Starter
Dadamsnv
1977 CJ5
Originally Posted by Matt1981CJ7 View Post
Dada,
Matt
Good info
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is offline
post #63 of 684 Old 08-07-2012, 01:09 PM
swatson454
1983 CJ7
Shoot, GM put "big" Q-Jets on grannys Caprice Classic with a smogged-to-death 305.
Shawn
Ok, I got a little carried away with "granny's Caprice Classic" but they did use a 650 cfm Q-Jet on some Monte Carlos with a 305 HO option; which is kind of an oxymoron, lol.
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #64 of 684 Old 08-07-2012, 04:12 PM Thread Starter
Dadamsnv
1977 CJ5
Shawn
Hmm...
It seems more and more as I read that the 470 may even be slightly under powered for the 304, but there isn't any real science behind it, just opinions. And more than a few people are running Q jets on their 304s, and ALL seem to love it! Some even use the 750 CFM Q jets with great success. Looks like the way to go I suppose. I like the Holley TA, buts that a $400 carb, and even with the mods, the Q jets still seems to out perform.
Dadamsnv is offline
post #65 of 684 Old 08-07-2012, 04:44 PM
Matt1981CJ7
1981 CJ7
Dada,
That's the same conclusion I came to. I believe there's something unique about the design that makes the Q-jet perform better than most at severe angles. When guys like John Nutter mention that many of his wheeling buddies use Q-jets on their 304s, and love them, I tend to pay attention. We'll see....
Based on the info from the thread I linked to earlier, it appears the stock Chevy 350 truck Q-jet setup works pretty well with the 304.
Matt
post #66 of 684 Old 08-07-2012, 05:10 PM Thread Starter
Dadamsnv
1977 CJ5
Dada,
Matt
Great!
All I need now is some spare $$$
until then, I will run the hell out of this holley 2300. Unfortunately, I need a new rad, hoses, and fan shroud. My JB welded rad just started to leak, it wont be long until it completely goes. Might as well beat it to the punch
Dadamsnv is offline
post #67 of 684 Old 08-08-2012, 12:05 AM Thread Starter
Dadamsnv
1977 CJ5
I bought a radiator, hoses, and timing gaskets, and I will be fixing some leaks and bad radiator stuff for the next few days.
Dadamsnv is offline
post #68 of 684 Old 08-09-2012, 12:24 AM Thread Starter
Dadamsnv
1977 CJ5
I was planning on replacing timing set, and my cam gears if needed, but when I pulled the timing cover off today, I found an uncharacteristically clean timing set, cam gears, and timing cover insides. I'm not sure how sloppy a new chain is, I've only done a magnum 360 before. Does this timing set look as good as I think it does? I know it's hard to tell from the pic, but I'm almost certain this is hardly used.
I figure I'll post this here since it deals with my timing, plus I will be experimenting with why my HEI vac advance points at the radiator fan.
Dadamsnv is offline
post #69 of 684 Old 08-09-2012, 12:27 AM
8pitcher
8pitcher's Avatar
Looks really clean to me. I wouldn't mess with it the chain looks almost new.
And could you post a pic of the inside of your timing cover? I have some circular grooves in mine and I wanna see if you do too so I will know if I have something wrong.
8pitcher is offline
post #70 of 684 Old 08-09-2012, 07:18 AM
86cj74.2L
86cj74.2L's Avatar
Put the harmonic balencer on before you tighten the cover bolts. It will help line up the seal.
86cj74.2L is offline
post #71 of 684 Old 08-09-2012, 07:29 AM
8pitcher
8pitcher's Avatar
I want to know if this is normal or really bad.
8pitcher is offline
post #72 of 684 Old 08-09-2012, 07:40 AM
Matt1981CJ7
1981 CJ7
8,
That looks pretty worn, to me.
For comparison, here is what the one I pulled off my 360 looked like.
Matt
post #73 of 684 Old 08-09-2012, 07:52 AM
8pitcher
8pitcher's Avatar
Thanks. What caused the oscillating circles though? Is there any concern?
8pitcher is offline
post #74 of 684 Old 08-09-2012, 08:13 AM
lsukevinc
1979 CJ5
so the vac line to the distrubutor should come off of the manifold and not the carb?
lsukevinc is offline
post #75 of 684 Old 08-09-2012, 08:46 AM
Matt1981CJ7
1981 CJ7
I'm no expert, but I believe it's cased by cam walk. The AMC V8s have no thrust plate, or button, to prevent the cam from walking back and forth.
When it gets too sloppy, like yours apparently has gotten, it will start chewing up cam and dizzy gears, and stretch timing chains.
Matt
Having trouble searching TKFireman Jeep CJ Forum 0 12-24-2011 10:36 AM
weber tuning 32/36 & engine tuning help gingermesiah Jeep CJ Forum 37 10-14-2011 09:34 AM
radiator searching beachn1 Jeep CJ Forum 3 06-25-2011 07:29 AM
searching for a used CJ stk26485 Jeep CJ Forum 7 11-13-2004 01:14 PM
