Searching for the golden tuning - Page 45 - JeepForum.com
post #661 of 684 Old 06-04-2013, 02:39 PM
I6CJ7
The popping on decel is normal if you have a nice crisp lean idle mixture. Because your decelerating and your off the gas, its running on the idle circuit so there isn't enough fuel at the given speed and load, so you'll get the lean popping/burbling. (sounds awesome with headers)
Shawn could probably explain it better.
I6CJ7 is offline
post #662 of 684 Old 06-04-2013, 02:54 PM
ASteve
1972 CJ5
I6CJ7,
Thanks, I figured this out after I posted that. Should have followed up on that post too...Anyways, it started to happen more when I turned my screws in to 1.25 turns out from 2.0, and as you said when you lay off the gas your running on the lean mixture of the idle circuit.
Thanks for chiming in with that.
SC
ASteve is offline
post #663 of 684 Old 06-04-2013, 05:04 PM
I6CJ7
Yup no problem! At idle you should have a lean miss or stumble about every 7-8 seconds i believe, when its perfect.
And that lean popping will increase like you said as your lean out the screws more.
I love the sound of my headers, i need to get a sound clip of them.
I6CJ7 is offline
post #664 of 684 Old 06-08-2013, 01:34 PM Thread Starter
Dadamsnv
1977 CJ5
Touchdown with the two point conversion!
Touchdown obviously is that I passed smog.
Two point conv is that I went to a smog guy that knows his stuff about carbed wheeling rigs. He asked me how I tuned it and before he even put the probes in the exhaust, he turned my idles 1/3 turn in, and then he probed it and it passed smog! He said the vac tuning makes it too "fat" (see! He knows his terminology).
After the test he ran it on diagnose so he could see my numbers in real time, and he said I'm a jet lean on my mains. Good to know.
Then we BS'd about carbs for a sec. He asked me how I like the Holley off camber to which I replied about its painful weaknesses. You'll like this one Matt, he then recommended a Qjet and told me some shocking stories about what he's seen Qjets do offroad.
As if I wasn't sold before, I'm really sold on a qjet now!
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is offline
post #665 of 684 Old 06-08-2013, 02:39 PM
lucdog
lucdog's Avatar
1980 CJ5
Thats Good news.
Ask Matt who one of the guys was who recommend the Q-jet.
How's the job going so far?
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #666 of 684 Old 06-08-2013, 03:13 PM Thread Starter
Dadamsnv
1977 CJ5
Originally Posted by lucdog
Thats Good news.
Bill
If I remember correctly it was some guy named Pappa Billy, whoever that is
And I'm officially done with my last job, and I start the new one Monday. I'm psyched!!
Dadamsnv is offline
post #667 of 684 Old 08-18-2013, 11:18 PM Thread Starter
Dadamsnv
1977 CJ5
Originally Posted by Matt1981CJ7 View Post
As I understand it, the color change on the ground strap is an indication of heat range and timing, with heat range having the greatest effect.
To me, your plugs appear to have the correct heat range, your mixture looks good, and you could use slightly more timing.
Do you really think fuel was flowing thru the vent, causing flooding, on an incline? I'll be interested to see if your extension fixes that problem.
Matt
Hey guys, it's been a while for this thread, but...
Matt,
there wasn't an issue with fuel coming out of my float bowl vent after all. Remember that crazy fuel tube contraption thing I made? I'll repost the pic soon. My lean back stumble is something else. Probably a lack of a Qjet
Dadamsnv is offline
post #668 of 684 Old 09-02-2014, 08:24 AM
AZ_Chip
1981 FSJ Cherokee
Ah man, I wanted to see how ASteve's tune turned out. Wanted to know if Dada ever got married. Why do you guys leave us hanging like this?
AZ_Chip is offline
post #669 of 684 Old 09-02-2014, 09:55 AM Thread Starter
Dadamsnv
1977 CJ5
Not sure about Steve's tune, but I've been happily married for just over a year now!
As a random update, since I'm here, the best tuning things I've done for the jeep:
1. Ditched the summit dizzy for a DUI dizzy
2. Ditched the Holley for a Motorcraft 2150 from an AMC 360
Dadamsnv is offline
post #670 of 684 Old 09-02-2014, 10:07 AM
locohosa
Could this thread be used to get tuning advice from the masters if I were working on a 258 with a non stepper BBD?
Or is this cool V8 engines only?
1996 Dodge Ram Cummins, 5.9L, NV4500, 4x4
1955 M35A2
1984 CJ7 4.2 T176, on 33s
locohosa is offline
post #671 of 684 Old 09-02-2014, 10:52 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
It's best to start your own thread, so information doesn't get confused.
Matt
Matt1981CJ7 is offline
post #672 of 684 Old 09-02-2014, 05:08 PM
AZ_Chip
1981 FSJ Cherokee
Thanks! I was wondering if stock carb was the way to go on my 360. I don't know if the Edelbrock intake would accept a 2150. I am having a hard time getting the Edelbrock Performer 1400 to run right. I took it apart yesterday and I am thinking I need a new carb or different carb. I am not very car carb experienced.
The DUI dizzy removes the coil and motorcraft box from the system?
AZ_Chip is offline
post #673 of 684 Old 09-02-2014, 05:37 PM
Matt1981CJ7
1981 CJ7
AZ,
The Edelbrock intake is a standard square bore bolt pattern. The 2150 is a Holley bolt pattern. You would need an adapter.
Is your 1400 relatively new? What problems are you having with it? FWIW, I've been happy with my Q-jet on my 360 with a Eddy intake.
Matt
post #674 of 684 Old 09-02-2014, 06:55 PM
AZ_Chip
1981 FSJ Cherokee
AZ,
Matt
Not new. It is a 1400 which seems to have been built over 20 yrs ago.
Problems: Rough idle, hesitation during acceleration, not sure if electric choke is working, main jet on one side. But so many I am not wanting to fix it. It takes a lot of time to troubleshoot all these and I would like to drive soon and not be in the shop all this fall. I still need to re-route my fuel line from fuel pump.
In all I have many issues and no manual to work from. I have a vacuum switch on the intake with a brown wire going somewhere, I have vacuum switches with no lines, I had a vacuum line taped up. Being trying to fix all these just a little overwhelming at times. I am not usually a parts changer. I don't mind troubleshooting. But it builds up and I get a lot from this forum but still some questions are unanswered.
AZ_Chip is offline
post #675 of 684 Old 09-02-2014, 08:21 PM
Matt1981CJ7
1981 CJ7
First step...get a factory service manual for the year of your CJ. Without that, you're just chasing your tail.
Matt
Having trouble searching TKFireman Jeep CJ Forum 0 12-24-2011 10:36 AM
weber tuning 32/36 & engine tuning help gingermesiah Jeep CJ Forum 37 10-14-2011 09:34 AM
radiator searching beachn1 Jeep CJ Forum 3 06-25-2011 07:29 AM
searching for a used CJ stk26485 Jeep CJ Forum 7 11-13-2004 01:14 PM
