Searching for the golden tuning - Page 44 - JeepForum.com
post #646 of 684 Old 04-02-2013, 06:34 PM
ASteve
1972 CJ5
Daniel,
Me too...I've been reading and reading about:
  • Fuel line set up
  • Dead head fuel regulators
  • Fuel line sizing
  • Return line vs no return line
  • 90* angles in fuel lines
  • Fuel Pumps
  • Float settings for Holley
  • Heat shields
  • Fuel Pressure Regulator Mounting brackets
  • The list goes on...
Anyways, my Jeep is running but with my Fuel Pressure Regulator completely open. It will not run for a long period of time with the fuel pressure regulator adjusted to proper pressure. Venturies start to dribble after engine is warmed up for a bit and floods.
I'll figure this out later, and move onto my advance curve. I have some springs to mess with, but not sure they are stiff enough to what I currently have. I'll find out once I rip into my dizzy though...
I hope all is well with you Daniel. Also, I think your Mom's shop might be a blessing in disguise...Take her shop to a new level...customer service is huge!
All the best.
SC
ASteve is offline
post #647 of 684 Old 04-02-2013, 06:57 PM Thread Starter
Dadamsnv
1977 CJ5
Originally Posted by ASteve
Daniel,
[*]Fuel line set up[*]Dead head fuel regulators[*]Fuel line sizing[*]Return line vs no return line[*]90* angles in fuel lines[*]Fuel Pumps[*]Float settings for Holley[*]Heat shields[*]Fuel Pressure Regulator Mounting brackets[*]The list goes on...
All the best.
SC
That's great advice Steve! Thanks! I've been doing my best and its working out well, they've started to trust me with more major work. Like today I started and almost finished a rearend swap on newer mustang. Same axle as before, but the newer housing had upgraded axles, and a larger spline count pinion. Bummer is yolk on the new axle isn't compatible, but mustang parts are cheap. By almost finished i mean it needs a yolk, then I'll put the brakes on and the wheels and be done. Also did three oil changes all in 5 hours.
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is online now
post #648 of 684 Old 04-11-2013, 09:49 AM
8pitcher
8pitcher's Avatar
Alright so maybe you guys can help.
I redid most of my wiring and got it to where I should be able to start her up I put a little gas in the carb and cranked and got nothing any suggestions?
8pitcher is offline
post #649 of 684 Old 04-11-2013, 09:57 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Just to be clear, does the starter turn the crank, but the engine doesn't fire? Or does the starter not turn, and all you get is a "click" when you try to start?
Matt
Matt1981CJ7 is offline
post #650 of 684 Old 04-11-2013, 10:08 AM
8pitcher
8pitcher's Avatar
Matt
Crank but no fire
8pitcher is offline
post #651 of 684 Old 04-11-2013, 10:28 AM
Matt1981CJ7
1981 CJ7
Pull a plug wire, stick an old plug in it, and set it near a ground. Then crank the engine. If you don't see a spark, it's most likely the ICM wiring.
Matt
post #652 of 684 Old 04-23-2013, 10:55 AM
ASteve
1972 CJ5
Well...I'm still here. I have the fuel issue all sorted out and the jeep is running great! I've put 4 tanks of gas through the new set up and I'm getting around 12 MPG around town driving. Before I was getting around 8-11 but the 11 was a rare thing with 9 being a good average. So, I did pick up 3 MPG which is a good thing...
Mixture screws are set out at 1.25 turns with 16" of manifold vacuum. Seems that's the sweet spot...
Problem I'm having right now is that in decel my mufflers are popping and assume this is a manifold leak. This all started when I installed the thick gasket between the intake and carb. I need to correct this first and get back to the tune...
Sorry guys, but be patient...I'm getting there ...
SC
ASteve is offline
post #653 of 684 Old 06-02-2013, 11:42 PM Thread Starter
Dadamsnv
1977 CJ5
So to pilot this thread for a while, my CJ refused to pass smog, and then failed again after me tuning it. So I've been kicking myself thinking my tune is apparently a golden turd, but i was pondering this evening why it would pass last year while running like crap, but won't pass this year running like a beast, and I think I may have realized it.
For information's sake, I failed because at idle I produce double the CO and double the hydrocarbons I should indicating I was too rich. So I put leaner main jets in it (because its hot now and the mains effect the idle slightly), then I vac tuned the idle screws. I dropped my hydrocarbons close to passing, but my CO went up!?
So I did some readings and it seems retarding your timing and retuning will lower your numbers. Then I realized since I run on manifold vac, my timing at idle is very high! Correlation! So I think I will simply port my vacuum advance and try it again when I get the chance.
What do the pros say?
post #654 of 684 Old 06-03-2013, 06:05 AM
swatson454
1983 CJ7
Yeppers. Drop the initial down a couple of degrees and get it back on ported vacuum advance. Once you pass, make it run like it should again
Shawn
Edit: Now that I think about it, that should've been mentioned. My bad
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #655 of 684 Old 06-03-2013, 08:26 PM Thread Starter
Dadamsnv
1977 CJ5
Shawn
No worries man. A Lot of good info has been learned here in this thread, and now this will stick extra hard with me
If I pass tomorrow, I'll be stoked that I figured it out! If not, I'll try something new.
post #656 of 684 Old 06-03-2013, 09:55 PM
ASteve
1972 CJ5
Daniel,
Great work! I would of totally forgot about the manifold vac advancing the timing at idle...fingers crossed and I can't wait to hear what happens tomorrow.
Hey, on another note...when you plot your centrifugal curve is it necessary to plug the end of the vacuum line that is attached to the distributor or does it matter?
SC
ASteve is offline
post #657 of 684 Old 06-03-2013, 10:35 PM Thread Starter
Dadamsnv
1977 CJ5
Daniel,
SC
Thanks Steve! I think I'll postpone the test until the weekend. I'd have to leave the jeep in an unattended, unsurveillanced parking garage in downtown loonyville for 12 hrs while I'm at work in hopes of making it to the smog place by 7 PM. I got to thinking about how sketchy that was, an then I backed out. But Saturday is the day!
Also, it shouldn't matter if you don't plug the dizzy end of the vac line. There's no way anything can draw enough vac through that line to change the timing. And it's likely you wouldn't get contaminants in the few moments it would be disconnected.
post #658 of 684 Old 06-04-2013, 09:30 AM
ASteve
1972 CJ5
Thanks Daniel.
I figured, but just wanted to make sure I was not missing something...
Good luck!
SC
ASteve is offline
post #659 of 684 Old 06-04-2013, 11:34 AM
Matt1981CJ7
1981 CJ7
Steve, if you disconnect the vac line at the dizzy, while keeping it hooked up to a vac source, then yes you will need to plug the line.
If you disconnect the vac advance line at the source, then you need to cap the source.
Clear as mud?
Matt
post #660 of 684 Old 06-04-2013, 11:41 AM
ASteve
1972 CJ5
Got it!
Still need to plot my curve one more time...just to make sure I'm reading what I'm reading...
SC
ASteve is offline
Having trouble searching TKFireman Jeep CJ Forum 0 12-24-2011 10:36 AM
weber tuning 32/36 & engine tuning help gingermesiah Jeep CJ Forum 37 10-14-2011 09:34 AM
radiator searching beachn1 Jeep CJ Forum 3 06-25-2011 07:29 AM
searching for a used CJ stk26485 Jeep CJ Forum 7 11-13-2004 01:14 PM
