Quantcast Scrambler project - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Scrambler project
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire Carrier4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed
Old 06-05-2009, 06:28 PM   #46
Crockett
Originally Posted by Rollbar View Post
I might have missed it but where did U get your tie-rods?
Thanks,
Jim
its the currie kit. and im having some real trouble with it. the tie rod and drag link are too large in diameter and hit each other and the springs. so i redrilled the knuckels and moved them to the top and they clear alot better but i have a feeling im going to have to make my own pitman arm so the drag link clears it when i flex it.
Crockett is offline   Reply With Quote
Old 06-05-2009, 06:34 PM   #47
Rollbar
1984 CJ8
Thanks, got a pic of the existing?
*MY CJ IS YOUR yJ's DADDY*
Project CJ8 Build Gallery <----Click
CJ8 Build Thread<---- Click
Rollbar is offline   Reply With Quote
Old 06-07-2009, 06:04 PM   #48
Crockett
Old 08-04-2009, 11:31 PM   #49
Crockett
got a few updates.
Old 08-05-2009, 06:17 AM   #50
Tigger01
And I was wondering were you have been Crockett
That thing is looking good and the body is back primed up
and motor is brightened up looks cool
What color is the paint going to be and what was the body lined with
tigger
Tigger01 is offline   Reply With Quote
Old 08-05-2009, 08:20 AM   #51
Crockett
the body is Ricks pro coated( a local shop has there own brand of line x basically but it looks better). Its coated in the engine bay and the whole underside, and the inside will be done after paint. the paint will be chevy metalic green. so far the running total is 33798.56. hopfully it will be at paint by monday. its a little taller that what was wanted. I seem to have a problem with my tires sticking in way too far. i planned on needing wheel spacers but i need a 2" spacer in the rear. does anyone know of a spacer that large and is it safe.
Old 08-05-2009, 10:52 AM   #52
trailridin4x4x4
1981 CJ7
doesn't look like you need those fender flares the tires barley stick out past the openings on the tub and fenders........nice build though wow 33,798.56 that's huge
trailridin4x4x4 is offline   Reply With Quote
Old 08-05-2009, 10:57 AM   #53
duckn
1978 CJ5
Very nice!
duckn is offline   Reply With Quote
Old 08-05-2009, 11:34 AM   #54
Crockett
well i have to space the rear out because its hitting the springs
Old 08-05-2009, 12:18 PM   #55
DT5150
1983 CJ7
coming along nicely. good work.
83 CJ-7. TBI Small Block Chevy 350/TH350/D300, Scout II Dana 44 front, CJ Dana 44 rear. 4" BDS Lift with 35's.
DT5150 is offline   Reply With Quote
Old 08-05-2009, 12:20 PM   #56
Ziptie2k2
OK, I'll bite. I've not seen linkage like that for that T-Case. Is it electronically shifted? Looks nice. Great work so far.
1977 - CJ7.......1979 CJ7.......1981 - CJ8.......1986 CJ7 Cant get enough!
Originally Posted by 442Wrangler View Post
where do you believe you go when you die?
Originally Posted by sanchagrins View Post
you go in the ground, duh.....
Ziptie2k2 is offline   Reply With Quote
Old 08-05-2009, 07:49 PM   #57
Crockett
no its a northwest fab creation. i was just looking for something cool to do for the transfer case and saw those on a show and decided to try them. does anyone know of a 2 inch wheel spacer
Old 08-05-2009, 09:08 PM   #58
Ziptie2k2
I've seen em on Ebay, but as far as safe goes... Who knows.
Old 08-05-2009, 09:41 PM   #59
kickingprop
No FunHaters Allowed!
kickingprop's Avatar
Spidertrax makes some good ones
http://www.spidertrax.com/s.nl/it.A/id.2287/.f
1985 CJ7 Project
Phase One : 5.3L Vortec/4L60E, Moser axles for AMC20, Twin Stick'd Dana300 - Completed
Phase Two: Bedliner, Rollcage, Seats, BESRK Rear Bumper w/ tire swing, Soft Top, and a few other goodies - Mostly Complete
Phase Three: Waggy 44 front, Scout D44 Rear, 4.56's, ARB's (F/R) SOA with YJ Springs, 35x12.50x15 BFG MT - Not Even Close to beginning
Also a mostly rust-free 1970 Scout 800A That I'll get to start working on someday...
Chrome won't get you home...BUT Rattle Can Black may just get you back"
kickingprop is offline   Reply With Quote
Old 08-05-2009, 10:52 PM   #60
Crockett
yeah i saw those but there not big enough
Glock Forum
