scrambler half hard top question - JeepForum.com
post #1 of 18 Old 11-04-2009, 05:30 PM Thread Starter
daltonw
1981 CJ7
Does anybody by chance know what size of bolts are used to bolt the hard top to the bulk head on a cj8?
daltonw is offline
post #2 of 18 Old 11-04-2009, 05:44 PM
Olrev
1981 CJ7
Well, I don't know the thread size...but it takes a 1/2 socket. It's the same bolt that holds the full size hard top on...at least it was in mine.
http://picasaweb.google.com/outtopas...11959416196450
81CJ7, 258, MC2100, TeamRush'd, 3"lift, 34x10.50TSL's, 3:31gears, Scrambler cab
Olrev is offline
post #3 of 18 Old 11-04-2009, 08:36 PM
red mistress
1983 CJ8
5/16"
5/16" course thread
67 Gladiator 15K AMC327 PTO Ramsey D44, D60 69 Jeepster deluxe Convertible Power 82 CJ-8 75K Renegade all original 83 CJ-8 50K 401 MPFI ARB60's front & rear winch 38" 84 CJ-7 38K Garnet interior, Jeep SE 8274, 8" x 33" 87 J20 36K Jeep SE Hidden winch, boat rack, 35" 2006 LJ Rubicon 3K
red mistress is offline
post #4 of 18 Old 11-04-2009, 09:04 PM Thread Starter
daltonw
1981 CJ7
Originally Posted by red mistress View Post
5/16" course thread
THANK YOU VERY MUCH!!!!!!!
daltonw is offline
post #5 of 18 Old 11-05-2009, 11:17 AM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
I have some extra factory hardtop bolts and thread plates if you are interested in the exact setup. I don't know exactly how many, but I know I have some. The bolts aren't anything special (as mentioned above), but the thread plates are rather specific and they will fit correctly under the flange lip.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #6 of 18 Old 11-05-2009, 11:58 AM Thread Starter
daltonw
1981 CJ7
I have the threaded plates but no bolts came with it. The PO must have messed up the threads or something because 5/16 is too small. 3/8 is too big. 8mm is to small. I can't figure this out
daltonw is offline
post #7 of 18 Old 11-05-2009, 01:01 PM
PavementPounder
Cool as Ice...
That's quite possible, as I have discovered a number of them that were cross-threaded over the years. That's why I started collecting extras as I found them.
Are you sure that your plates are OEM and not something that the PO made themselves? IIRC, they should have rounded edges on one side?
post #8 of 18 Old 11-05-2009, 01:34 PM Thread Starter
daltonw
1981 CJ7
Are you sure that your plates are OEM and not something that the PO made themselves? IIRC, they should have rounded edges on one side?[/QUOTE]
Yeah they look original to me. I just ended up putting 3/8 screws in! Just drilled em right on up and in and it tightened the top done perfectly.
daltonw is offline
post #9 of 18 Old 11-05-2009, 03:51 PM
John N
1981 CJ8
The OEM pieces in the top are only sheet metal. Once they strip, they won't even hold a heilicoil, I tried. I even moved up to 3/8" bolts, but they stripped out eventually, too. I drilled 1" round holes above where each of the 4 bolts go in the top. Then I fish in a square nut each Fall when I put the top back on. Once a year isn't bad to deal with it.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #10 of 18 Old 11-05-2009, 06:21 PM
PavementPounder
Cool as Ice...
We're talking about where the top attaches to the bulkhead, not along the top of the windshield. I agree that's a PITA area once the holes get too big. People typically do a latch conversion once it gets too bad.
post #11 of 18 Old 11-05-2009, 07:55 PM
John N
1981 CJ8
We're talking about where the top attaches to the bulkhead, ............
That's exactly what I'm talking about too........read my answer again.
John N
John N is offline
post #12 of 18 Old 11-05-2009, 09:10 PM
PavementPounder
Cool as Ice...
The bolts that hold the half-cab hardtop to the bulkhead do not thread into sheetmetal. I don't understand what it is that you posted a picture of. The one I had did not have rivets in the roof.
Do you have a pic that is not so close?
post #13 of 18 Old 11-05-2009, 09:13 PM Thread Starter
daltonw
1981 CJ7
I understand that pic. And thats where i was having trouble so i put 3/8 screws in that hole because I couldn't find a bolt, metric or standard to fit.
daltonw is offline
post #14 of 18 Old 11-05-2009, 09:16 PM Thread Starter
daltonw
1981 CJ7
I think I'm going to do that tomorrow! Drill holes so i can put a nut in there and really snug it down and not worry about the screws working loose or falling out at some point.
daltonw is offline
post #15 of 18 Old 11-05-2009, 09:18 PM
PavementPounder
Cool as Ice...
I must not be remembering the roof correctly, then. I thought mine bolted to the body vertically with the same fasteners that a CJ-7 roof used - a bolt through a threaded plate which sandwiched the roof flange to the body flange. Where is that hole?
cj7 with cj8 half hard top dkap Jeep CJ Forum 82 03-26-2012 06:03 PM
Scrambler hard-halftop fit a cj7? M79 Jeep CJ Forum 4 11-30-2007 10:04 PM
Scrambler half cab and early CJ roll bar mocked up.... webejpn01 Jeep CJ Forum 3 07-10-2007 08:32 AM
cj8 half hard top on a YJ? yjing Jeep CJ Forum 1 05-09-2006 10:33 PM
lift kit for a full hard top scrambler PostalCJ-8 Jeep CJ Forum 1 03-22-2002 06:48 PM
