Scrambler Body Mounts - JeepForum.com
post #1 of 8 Old 06-28-2013, 11:18 PM Thread Starter
CW81Scrambler
1981 CJ8
What would it cost to replace a body mount on my Scrambler? I don't have the stuff to do it myself.
CW81Scrambler is offline
post #2 of 8 Old 06-29-2013, 05:20 AM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
That depends on how many and how much the body bolts are rusted. Sometimes the captured nut for certain ones will break loose and that is a pita.
Assuming no real issues, a good mechanic should be able to do it within 2 hours.
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #3 of 8 Old 06-29-2013, 08:50 AM
jeepwhore
And that would be slow. If the bolts don't break all you need is a hi lift jack, a block of wood and a ratchet and socket of appropriate size. When I put in my body lift I think it took me about 2 hours to replace all the mounts (in the driveway)......but then again I was working with a rust free YJ tub.
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline
post #4 of 8 Old 06-29-2013, 12:40 PM
John N
1981 CJ8
There are several threads over on http://www.cj-8.com/forum/index.php about doing this. A lot depends on just how extensive the repair is, it can be a lot more than you see or less.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #5 of 8 Old 06-29-2013, 12:55 PM
Spieg8
1984 CJ8
Are you wanting to replace the actual mount, or just the bushing?
Spieg8 is offline
post #6 of 8 Old 06-29-2013, 11:34 PM Thread Starter
CW81Scrambler
1981 CJ8
The actual mount. The rest are fine but the one looks like crap. It's pretty rusted up.
post #7 of 8 Old 06-30-2013, 12:24 AM
Spieg8
1984 CJ8
If it's just the sheet metal where the nut goes, it's relatively easy to cut and patch. probably a couple hundred bucks to do one.
If you're talking about an outrigger on the frame, I'd hesitate to make a guess, although I don't think it will be cheap or easy. They need to weld on both the top and bottom of the mount (which requires the tub to be lifted a good 8-10" off the frame to get a welder between the tub and frame). That'll mean a lot of electrical/mechanical stuff has to be disconnected (think brake lines, coolant lines, fuel lines, clutch linkage, etc...).
Hope it all works out well.
Spieg8 is offline
post #8 of 8 Old 06-30-2013, 07:48 PM Thread Starter
CW81Scrambler
1981 CJ8
Thanks
