scout dana 44 axle? - JeepForum.com
post #1 of 12 Old 03-29-2006, 06:54 AM Thread Starter
cj7junkie
Question scout dana 44 axle?
My buddy is going to sell me some scout dana 44 axles. I have a 1980 cj7, and i already checked if they fit onto my jeep and they will. The axles have been sitting in a field for a few years and i was wondering about how much its going to cost to redo them. My rig is gonna be a daily driver, sand dunes, and a hunting rig. I plan on rebuilding my 350 chevy in the future thats why i was told to get rid of the amc 20 in the rear and the dana 30 in the front. I plan on running 300-400 horspower. The amc 20 already has heavy duty one piece axles in the rear, the biggest tire i plan on running will be a 35" tire. What do you guys think i should do? Any help would be greatly appreciated.
cj7junkie is offline
post #2 of 12 Old 03-29-2006, 09:04 AM
jlynch
I would keep what you have and get some heavy duty replacement shafts for your model 30. I run 36" tires with a 20/30 setup with little problems. Mine is a off road jeep only. I will break a shaft on the 30 every now and them but its an easy fix. your model 20 will be just as strong as the scout 44.
92 Jeep wrangler/ Chevy 350/ sm465/ 205/ Dana 60/ Dana 70/ 4.56 gears/ detroit locker/
jlynch is offline
post #3 of 12 Old 03-29-2006, 09:36 AM
jeepskate
It's not a direct bolt-in (you'll have to cut & reweld the rear perches, up front you'll have to outboard your springs and cut & turn the knuckles to set proper caster). For all of that effort, you're not going to buy yourself much if any advantage in the rear...just weld & truss your AMC 20. The 30 will be right about at it's limits, but should hold up if you upgrade the shafts (Warn, Yukon, AlloyUSA, etc) & u-joints, replace the hub bolts with studs, and replace the the stock lockouts with better quality aftermarket ones (Superwinch, Warn, Milemarker).
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #4 of 12 Old 03-29-2006, 09:57 AM Thread Starter
cj7junkie
what would you weld and truss on the axles...forgive me i'm new to the jeep mod scene.
post #5 of 12 Old 03-29-2006, 10:24 AM
jeepskate
http://www.jeepforum.com/forum/f8/amc-20-too-weak-my-setup-255346/
post #6 of 12 Old 03-29-2006, 12:56 PM
CJ51973
CJ51973's Avatar
That's a pretty complex one. I'll look around and see if I can find simpler version.
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
post #7 of 12 Old 03-29-2006, 01:14 PM
CJ51973
CJ51973's Avatar
Here are some pictures and some sources. 4WD Hardware also sells one.
Con-Ferr
Dept FW
2102 B Kenmere Ave.
Burbank, CA 91504
818/848-6993
www.conferr.com
Missouri Off Road Outfitters
Dept FW
907 Keg St.
Marshall, MO 65340
660/886-3834
www.mo-offroad.com
Poison Spyder Customs
Dept. FW
2140 W. Dartmouth
Englewood, CO 80110
303/777-4820
www.poisonspydercustoms.com
CJ51973 is offline
post #8 of 12 Old 03-29-2006, 01:37 PM
jeepskate
M.O.O. went out of business, that's why we made the one in the other post. It's complex because it's removeable and also serves as a mount for a 'bam-bar' on an SOA'd rig. Something simple like the PSC one would obviously be a good way to go if you just want to weld-on something simple and go. I wouldn't bother with the under the axle ones (Go Rhino!, Con-Ferr) unless you don't mind the loss of ground clearance.
post #9 of 12 Old 03-29-2006, 01:37 PM
18to80DDC
Built Not Bought
18to80DDC's Avatar
The second one is out of business
2001 4.0L Wrangler Sport - 3.5" lift on 33's
1973 CJ5 360 - 4" lift on 35's
1982 CJ7 360 - 2" lift on 32's
1971 Series III E-type Jaguar V12 - no lift...
18to80DDC is offline
post #10 of 12 Old 03-29-2006, 06:09 PM Thread Starter
cj7junkie
ok i see now. thanks guys.
post #11 of 12 Old 03-30-2006, 09:18 AM
kbtriumph
kbtriumph's Avatar
If you are going to be running 300-400 HP a D44 will not hold up. I would setp up to a Ford 9" or D60's.
I am replacing the D44's in my 100 HP rock crawler with 9 inchers and 35 spline axles because I keep twisting axles. I like the small profile and light weight compaired to a D60.
'43 GPW Rock Crawler
'74 CJ6 Safari
'98 TJ DD
kbtriumph is offline
post #12 of 12 Old 03-30-2006, 11:12 AM
wijeepguy716
RE: scout axles
I rebuilt a couple scout axles about 2 tears ago. I spent about 1500-2000 on them, front and rear 4.10's, a lock-right in the rear, one used rear axle, three front axles. parts for these are getting hard to find so i would make sure all the shafts are good otherwise go for it. you will have alot of fabricating to get them in but it will be worth it
wijeepguy716 is offline
scout 800 dana 44? BigTDog Jeep CJ Forum 5 03-01-2009 10:37 AM
Scout II Dana 44's Jeff5886 Jeep CJ Forum 3 11-18-2007 12:01 AM
scout dana 44 maine jeepster Jeep CJ Forum 18 10-22-2006 01:16 AM
scout dana 44 jlynch Jeep CJ Forum 9 06-28-2006 09:58 AM
Scout dana 20 vs jeep dana 20 (internal gears) pityocamptes Jeep CJ Forum 3 05-19-2004 12:19 AM
