Scott's Build Thread- 85 CJ7 - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Scott's Build Thread- 85 CJ7
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 01-23-2011, 01:41 PM   #91
Skerr
Seat Repair
My buckets were completely toast. I looked at all the same ones you guys have looked at, and settled on the "cheap" ones. While junkyard shopping for an MC2100, I came across the Jeep graveyard. The owner said he hasn't had a CJ since 1987, but there are several Cherry-Okees (as my youngest calls them!) a couple Comanches, and various and sundry Jeeps! The Comanche caught my eye and I figured the width would be about right. The bench was in good shape... cost me $30. I like buckets, but I love benches. You can lay stuff next to you, your best girl can sit next to you, you can sit three up front. I don't care about access to the back of my Jeep. If anything living is back there it will be a dog or a kid, and they can both climb over! So this worked out well. I have already posted the build for the bracket, so here is the repair. All I can figure is that Bubba and Bubba's friend rode around in this Comanche a lot! The seat is squashed! So my endeavor was to fix the hole I slid into with my narrow butt! Following is the exciting blow by blow description!
First... the seat. I have already installed it into my 7 so the bracket you see is mine. But this is how the seat looked after removing from the Comanch!
I removed the back and then turned the seat over. Here you can see the plastic clips that hold the slip cover on.
Carefully slip the cover over the edges to expose the foam. Depending on how rough your original cover is, it could be difficult to do. It could tear... so go slow. You can see a piece of closed-cell foam we receive in medical shipments. It is used as insulation, but now it is a Jeep part! This is a test fit.
The foam is too thick to use as is, so I need to halve it. I don't know a good way to do this! I used a very sharp knife. It's kind of like caping a game animal. It's easy to get off and gouge a hole, so go slow.
Here are the two halves... one for each side. Even though I went slow, it still looks like crap! So what... my rearend will be sitting on it!
I beveled the edges using boning scissors. If you leave the edges thick and vertical, you will probably not have as nice a finish, and you could possibly feel it while sitting on it. I wanted a good fit so as not to stretch my tired upholstery too much.
Test fit the cut piece.
Now this stuff is amazing stuff! Did I say it was amazing? It's amazing!! I used it as an adhesive to keep the foam from sliding under the slip cover.
Both sides installed. You can make your foam replacement any size you wish. You can rebuild the seat to pretty much any configuration if that is your goal. I just wanted to remove the "holes", so I stayed within the original "outlines" for your butt.
Slip cover pulled back over and reinstalled. Looks pretty even across the top.
Finished product. If I wasn't so tired I would have picked it up and put it back on top of the work tables... should have done it for pic quality, but you get the idea.
Replacing foam will cause you to be raised up a little bit in the cab, so watch your headroom. I wanted to do the back too, but I was not able to remove the cover without damaging it, so it stays as is. Now I need to find me a seat cover and I'm good to go.
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 01-23-2011, 02:20 PM   #92
SonicR1
Originally Posted by Coiz View Post
^^^ What he said. Wait............. what?
Still foggy here!!!!
Nice work on the seat!!!
[COLOR="Red"]... I guess I'm gonna have to fix that too…….[/COLOR]
[URL="http://www.jeepforum.com/forum/f9/sonics-05-tj-build-1168663/#post10985489"][COLOR="yellow"]The TJ[/COLOR][/URL]
2005 Wrangler X 4.0/6 speed, Dana 30/Ford 8.8--4.88--Eaton E-Lockers, 35" MT/R, Smittybilt bumpers/rockers/winch, SonicFab tire carrier, RE 3.5 springs, Zone 1.25 BL, FullTraction 3 link upper rear, RE super flex lower rears, UCF ultra high skid and lo/pro mount, brown dog mml.
[URL="http://www.jeepforum.com/forum/f8/sonics-74-cj5-build-1106795/"][COLOR="DarkOrange"]1974 CJ5 BUILD THREAD[/COLOR][/URL]
SonicR1 is offline   Reply With Quote Quick reply to this message
Unread 01-23-2011, 02:22 PM   #93
SonicR1
Originally Posted by Skerr View Post
"...your best girl can sit next to you…"
Oh yeah, and now you are just dating yourself!!!
Unread 01-23-2011, 05:29 PM   #94
Jim1611
Jim1611's Avatar
Nice job on the seat Scott and not much invested. It really looks nice. I'll have to remember the shoe glue too.
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 01-23-2011, 05:58 PM   #95
Skerr
Is that an Old Man term? Guilty...
For me, right now, that's the key. Low cost to no cost! Thanks Jim.
Kerrdog
Go Fish! <*////><
Unread 01-23-2011, 06:05 PM   #96
243
1978 FSJ Cherokee
I like your repair to the bench seat Scott, well done.
And I prefer bench seats too, I think back to all the vehicles I drove over the years and most had bench seats and so far, I have lived to be 46 without a problem. I think my favorite was my 79 Waggie, I loved riding around in the fish bowl with 360 degree visibility.
1978 Cherokee, 360/T400/QT...5.3/4L60E/NP241C in the works...
243 is offline   Reply With Quote Quick reply to this message
Unread 01-23-2011, 06:24 PM   #97
Skerr
Thanks, Dave. I can't wait to set it back in the Jeep and try it out. I have to wait at least 24 hours for the Shoe Goo to set up. I also need to get a seat cover before I shred the original slip cover... the stitching is dry-rotted and will tear pretty quick with the bulk of the new foam. Should be "sitting up" from now on!
Kerrdog
Go Fish! <*////><
Unread 01-25-2011, 06:13 AM   #98
243
1978 FSJ Cherokee
It has been over 24hr's, where is the update
Unread 01-25-2011, 04:50 PM   #99
Skerr
Well... besides the rain, everything is very tense in the house tonight! Momma's on the war path! Walking on egg shells and sneaking JF. Huh???... gotta go!
Kerrdog
Go Fish! <*////><
Unread 01-25-2011, 05:04 PM   #100
SonicR1
Uh, what did you do to piss her off???
Unread 01-25-2011, 05:17 PM   #101
Skerr
Really?? Does there have to be a reason. She just is... !!!! I'm not sure that I did it...
Kerrdog
Go Fish! <*////><
Unread 01-25-2011, 05:37 PM   #102
Jim1611
Jim1611's Avatar
Time to write another poem buddy.
My build thread
Unread 01-25-2011, 05:54 PM   #103
Skerr
I did better than that...
I grabbed her by the back of the head, pulled her close and tight, and kissed her hard on the mouth! Now she is fixing my ice cream...
Kerrdog
Go Fish! <*////><
Unread 01-25-2011, 06:13 PM   #104
benullman
1981 CJ7
Bull! Shes probably still running around mad steaming. Except now shes yelling RAPE!!
[QUOTE=Gregg79CJ7304;11634021]Great minds think alike, but so do serial killers......Thanks.[/QUOTE]
benullman is offline   Reply With Quote Quick reply to this message
Unread 01-25-2011, 06:25 PM   #105
Jim1611
Jim1611's Avatar
Sounds like you have the situation well under control. I knew you'd think of something.
My build thread
