Scott's Build Thread- 85 CJ7 - Page 20 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Scott's Build Thread- 85 CJ7
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 11-08-2012, 04:53 PM   #286
Skerr
Here is my WS frame after 2 apps of Ospho, curing for 24 hours each app. Pic of it as I removed it from the hanger, and a pic after wire brushing. I guess I will get some stripper to remove the remaining paint, but in the meantime, the rust is stopped. Notice the holes. Not sure what I am going to do yet. I would really like to avois welding on this frame, because of the warp factor, but it may be unavoidable.
Maybe I'll see if I can just encase it in DuraGlas.
Hmmm... Brown Santa just pulled up!!!!
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 11-08-2012, 04:59 PM   #287
Skerr
Happy Feet!
Kerrdog
Go Fish! <*////><
Unread 11-08-2012, 05:15 PM   #288
gmakra
Much mo betta than them stinky ole shoes you used to say was your hi performance slippers.
gmakra is offline   Reply With Quote Quick reply to this message
Unread 11-08-2012, 05:24 PM   #289
Skerr
They are STILL high performance. That's why I can run so fast, cut so sharp, and jump so high! Dontchu no nuthin?
Kerrdog
Go Fish! <*////><
Unread 11-08-2012, 05:37 PM   #290
MoC
Originally Posted by Skerr View Post
Happy Feet!
Looks like you can stick your foot right up a imates azz with those!
Frame is coming along nice!
MoC is offline   Reply With Quote Quick reply to this message
Unread 11-08-2012, 08:11 PM   #291
Skerr
Shoulda bought a pair of these years ago. VERY nice!
The WS frame is drowning me in sorrow!
Kerrdog
Go Fish! <*////><
Unread 11-08-2012, 08:50 PM   #292
lucdog
lucdog's Avatar
1980 CJ5
O brother, you want some cheese with your wine.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 11-09-2012, 04:40 AM   #293
gmakra
See Skipper you shoot yer self in the foot with an AK-47 then reload and do the same thing again.
You dont try to remove rust while your drowning the item in tears.
And don try to electric weld when your tears are a streaming, thats a good way to get shocked!
Unread 11-09-2012, 01:04 PM   #294
Renegade82
1982 CJ7
I would think with those short flat surfaces and 90 degree angles, that the metal wouldn't warp easily. Provided you went slow and kept it cool, and only used tack welds instead of short stitch welds.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
http://www.jeepforum.com/forum/f8/30...e-off-1280850/
Renegade82 is offline   Reply With Quote Quick reply to this message
Unread 11-09-2012, 03:35 PM   #295
spward
spward's Avatar
A long, long time ago I was working for a company that sold chemical pumps. I had to pickup some parts at a welders and noticed a guy welding on a magnet attached to a shaft that was in a bucket of ice. That was the only way to keep it cool during the process. Not sure if this would help.
Scott
USN Hull #227
spward is offline   Reply With Quote Quick reply to this message
Unread 11-13-2012, 05:02 PM   #296
Skerr
OHH- EMM- GEE!
This windshield frame is making me butt-stuck! I thought, just this morning, I would get SMART and sand-blast the poor little critter. But I have spent all the live-loong DAY on it. I am tired. I am hungry. Wife!! Where's me tay?
So... I picked up me little bags of sand and started dumping it in the hopper. Only to find that some of it was wet. Soooooooo... I spread it out on the driveway to dry in the placid sun. Low heat, low humidity today. Perfect for sandblasting. Dried in 45 minutes. Good to go.
I had trouble from the start. The old paint blasted right off the frame, but I lost air pressure so quickly that I couldn't get anything done. I constantly had to stop and let the tank pressurize, and my compressor (60 gallon) never, ever caught up. Sooooooooooooooooooooooo... I went and disced up the garden!
After the garden was done, and I had my mind right, I came back to the WS frame. UGH! I was having the same issue, and I got to thinking about all the sand I was wasting, so I supposed that if I put a smaller nozzle in the deadman it would use less air and concentrate the sand more, should go faster... right?
DUH! I replaced the nozzle, and the old one was completely shot. The new nozzle made all the difference, and it went speedily. Of course, my next-door neighbor came over and stopped me... he needed help moving a dead goat! So after moving the dead goat I finished the frame in, like, 15 minutes. I hung the spotless frame and shot it with Ospho.
I do NOT plan to go through all this with the whole Jeep. Ain't gonna do it! Here are some action shots...
1) HF 110# blaster. Works good when you strain the sand. I'm using play sand. Operates best between 60-100 PSI. My 60 Gal compressor will not keep up with that. Okay at 45 PSI.
2) My frame partially done. I taped the holes with masking tape, thinking I would keep the sand out of the frame, but that was a truly dumb idea! Didn't work, and the tape is next to impossible to get off after it has been sand blasted!! So don't so that!
3) Frame is done. Finally. All freakin day!
4) Bad spot... new metal going here.
5) Worn out tip, and the reason it was difficult.
Kerrdog
Go Fish! <*////><
Unread 11-13-2012, 06:38 PM   #297
hasselback
I did my whole frame with the exact same blaster on a 60 gallon compressor. Took almost a month. Went through probably 800 pounds of sand, which turned my gravel driveway into a nice sandbox! Was my first time sandblasting, and didn't realize the nozzles wear out until I was about half way done, haha! Started replacing nozzles for every 100 pounds of sand, and it went alot quicker!
hasselback is offline   Reply With Quote Quick reply to this message
Unread 11-13-2012, 08:04 PM   #298
Skerr
Im a sandblasting Noob! I thought you just dumped in the sand, connected the air, and blasted! It isn't a LOT different than that, but there are some things I learned that are helpful.
Strain the sand, unless you are using a quality media. I use my wife's large ktichen strainer. She's still a little touchy about that... guess I better replace it. I really don't like gritty M&C!
Keep a good tip on the gun/nozzle (deadman).
I went through 200# of sand on the frame!! After changing the nozzle it was very efficient.
Kerrdog
Go Fish! <*////><
Unread 11-13-2012, 11:19 PM   #299
8pitcher
8pitcher's Avatar
Haha I took my stuff to the sandblaster/powdercoater and got both done for $200 with a color change
Built Not Bought #640
8pitcher is offline   Reply With Quote Quick reply to this message
Unread 11-14-2012, 06:45 PM   #300
Skerr
Yeah, I remember that Trent. Came out real nice.
Kerrdog
Go Fish! <*////><
