Scary Brakes - JeepForum.com
post #1 of 7 Old 09-22-2002, 02:45 PM Thread Starter
diggy
Scary Brakes
While I was driving today. My streering suddenly wanted to keep pulling to the left. when i went to stop the brake pedal was solid and wouldn't move further than a few inches. And there was very little braking power. when I finally stopped, the front driver hub was smoking. When I finally made it home, and turned the wheel to full lock, there was a loud snap. Now I'm a afraid to move it an inch!
Diggy
P.S. 79 cj5 304 possibly for sale. lol
diggy is offline
post #2 of 7 Old 09-22-2002, 04:53 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
Sounds like the hub bearings went out...I had this happen to my 79 CJ. It's not real expensive to fix - around here (Socal) you can pick up a whole hub assy with bearings and seal for about $60...Plan to spend an additional $75 if the spindle is toast though!
Steve
OldJeepguy is offline
post #3 of 7 Old 09-22-2002, 06:56 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Front disks? Might check the caliper. It's possable that it is hanging causing the brake pads to drag. You will still want to repack the wheel and spinddle bearings.
jeepdaddy2000 is offline
post #4 of 7 Old 09-23-2002, 06:43 PM Thread Starter
diggy
do you believe this
Thanks for the help.
Anyway. I took my jeep to the garage today to have them check my hub. they said I must have what they call a lazy piston in my brakes. they told me they could find no problems and even took it for a ride. As soon as I left the lot it started to pull to the left. I grabbed the mechanic and had him hop in for a ride around the block. He said " oh that! All CJs, do that" BULL SHEIT!! He said that could be fixed with an alignment and to me to come back later. I come back pay hit the road and the same thing happens. His excuse " My machine can't align modified vehicles. Only stock!
Am I wrong, or is he feeding me a pile?
Diggy
diggy is offline
post #5 of 7 Old 09-23-2002, 07:11 PM
jeepdaddy2000
1971 CJ5
While the pulling could be caused by alignment, the smoking hub couldn't. Disassembleand inspect the pistons, caliper the and the caliper mount. If you find that the brakes are to blame, you might need to turn the rotor to true it. I would still do the hub and spindle(bearing) pack to insure the grease hasn't melted out of the bearings, or the bearing(s) went south(A L A Old Jeep guy). As for your mechanic, It sounds like he doesn't wont to work on it. It may be because of the mods, since liability is such an issue.
post #6 of 7 Old 09-23-2002, 07:53 PM Thread Starter
diggy
thanks jeepdaddy2000. looks like I have a another fun weekend ahead of me. lol
diggy is offline
post #7 of 7 Old 09-23-2002, 08:41 PM
Lightningdon
Lightningdon's Avatar
Diggy, find a new shop! Sounds like a lazy mechanic to me. My local shop jumped right on my Jeep, replaced bearings and did the alignment, no probs!
Don
Lightningdon is offline
some scary steering issues macgyver0187 Jeep CJ Forum 16 04-05-2008 07:34 PM
CJ5 is scary. NMPhi767 Jeep CJ Forum 13 02-27-2006 05:48 PM
Scary Steering ollietonk Jeep CJ Forum 5 06-12-2004 05:24 PM
Scary Wander part II kornboy Jeep CJ Forum 2 04-21-2003 03:56 PM
scary front end troubles greeneggsnham Jeep CJ Forum 10 01-12-2003 09:21 AM
