SBC V8 --> NV4500 --> Dana 300 Tranny Configuration - JeepForum.com
post #1 of 8 Old 10-02-2013, 03:04 PM Thread Starter
JeepMonkey
Need some help. I distinctly remember reading somewhere on this forum about the ideal set up for an NV 4500 mated to the SBC and Dana 300. Something about getting a GM NV4500 (2WD or 4WD?) and swapping the tail shaft or tail housing of a dodge NV4500 in order to shorten the overall length of the transmission AND couple with the Dana 300.
Am I dreaming this or does this thread exist? I cannot find it if it does exist and could use some help.
FYI, looking to source a tranny and want to get the right one.
THanks,
JeepMonkey is offline
post #2 of 8 Old 10-02-2013, 04:05 PM
jeepwhore
Like this?
http://www.jeepforum.com/forum/f8/wh...300-a-1403463/
Or from other forums:
http://www.pirate4x4.com/forum/gener...0-dana300.html
http://forums.off-road.com/jeep-shor...confusion.html
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline
post #3 of 8 Old 10-02-2013, 06:21 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
Here's how I did it:
SBC
Dodge gas version NV4500
SBC bell housing.
Adapter between tranny and bell housing.
Dodge version bolts right to the Dana 300 as is.
Usual release bearing adapter stuff, pilot bushing/bearing/arm
I asked a ref if he could give me a technical foul for thinking bad things about him. He said, of course not. I said, well, I think you stink. And he gave me a technical. You can't trust em. -
Jimmy V
Pacfanweb is offline
post #4 of 8 Old 10-02-2013, 06:28 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
What are the differences between the gas & diesel versions of the NV4500? I have a 4WD diesel vèrsion from a Dodge 5.9L Cummins. It also has some type of overdrive unit as well.
I'd like to use it behind a SBC project.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #5 of 8 Old 10-02-2013, 06:54 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
Max
Diesel has a bigger output shaft. Won't work with a Dana 300.
Jimmy V
post #6 of 8 Old 10-02-2013, 07:04 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
The one I have needs a rebuild, and it needs a new input shaft as well. Maybe I can install a gas version mainshaft while I'm rebuilding it?
Max
Mean Max is offline
post #7 of 8 Old 10-02-2013, 07:07 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
Max
These dudes can tell you everything you need to know about the 4500.
Jimmy V
post #8 of 8 Old 10-02-2013, 07:12 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Thanks!
Max
Mean Max is offline
