Sank the CJ... - Page 2 - JeepForum.com
post #16 of 62 Old 04-25-2013, 10:57 PM
82JeepCJ7
1982 CJ7
If the ignition was fried, it would still turn over. I'd start with the battery (maybe steal the one from the wife's car) and then try it again.
When you drained the engine oil, was there water mixed in with it? If not, then I would not worry to much. As the engine heats up, it will boil off any water that is left. Just change it after 100 miles or so.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #17 of 62 Old 04-26-2013, 02:33 AM
John Strenk
John Strenk's Avatar
1976 CJ5
You could bypass the starter solenoid with some jumpers cables just to see if it cranks. Watch out for sparks though, wear some eye protection.
Take the plugs out just in case on of the cylinders did fill with water
John Strenk is offline
post #18 of 62 Old 04-26-2013, 06:11 AM
Nafpu
2012 KK Liberty
Originally Posted by vivimus View Post
On a lighter note, my dad asked when I got the boat... "Oh, nevermind. It's just that your Jeep has a waterline!!" Jerk...
Looks like your dad might have created a new name for your CJ!
95 YJ, gone...
80 CJ7, gone...
12 KK, still here...
Nafpu is offline
post #19 of 62 Old 04-26-2013, 06:25 AM
lucdog
lucdog's Avatar
1980 CJ5
I would also be concerned about the alternator .
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #20 of 62 Old 04-26-2013, 06:37 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Bill
And the wheel bearings.
Matt
Matt1981CJ7 is offline
post #21 of 62 Old 04-26-2013, 08:58 AM
scrapman
Jump the solenoid and get that thing started! The longer you let it sit with humidity in it, bad things will happen.
scrapman is offline
post #22 of 62 Old 04-26-2013, 08:58 AM
Renegade82
1982 CJ7
Originally Posted by Matt1981CJ7 View Post
I highly recommend always parking in gear. 1st or reverse, depending on which direction you're facing on the hill.
Matt
I could never for the life of me figure out why anyone, in any manual vehicle, would not park it IN gear. I've seen a lot of people that don't and I never understood why. Especially when e-brakes don't work as well holding it from rolling back as they do holding it from going forward. And all that stands between a stationary and a rolling danger is a small metal cog tooth that can sometime release for unknown reasons.
Not bustin' on you in particular vivimus. It's just one of those oddities in life that baffle ya.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #23 of 62 Old 04-26-2013, 10:29 AM
CJ7ROB
Some people forget that its still in gear when they go to start it, and the Jeep will jump Everyone's done it at some point in their lives..I always leave my sticks in gear too.
CJ7ROB is offline
post #24 of 62 Old 04-26-2013, 10:41 AM
82JeepCJ7
1982 CJ7
If they forget its in gear, maybe they should not be driving...
My e-brake has not worked in 20 years. I've always parked with a chock block, in gear, and with the wheels turned just in case.
post #25 of 62 Old 04-26-2013, 10:48 AM
CJ7ROB
So if you ever need to use your E-brake while your driving you jump out of it with your chock block too? I don't see what's so hard about actually adjusting/fixing an ebrake to work properly.
CJ7ROB is offline
post #26 of 62 Old 04-26-2013, 11:10 AM
roboto65
1976 CJ5
In some states you have to have a e brake to pass inspection.
They say money can't buy happiness but it can buy Jeep parts...and Jeep parts make me really Happy.
roboto65 is offline
post #27 of 62 Old 04-26-2013, 11:13 AM
titomars
1981 CJ7
I have owned nothing but manual transmission vehicles most all my life. I never leave them in gear. My parking brakes work always. They are as important to me as the service brakes. So when I do my brakes the parking brakes get service also. My CJ's parking brake will hold her on a pretty steep incline all by itself. But I would not leave my CJ on a 30%+ incline with just the parking brake engaged either. I would back it up with wheels turned and chocking still in neutral. That being said with heavy trucks it is a golden rule, NEVER leave it in gear.
1981 Jeep CJ7 4.0 HO, AX-15, D300, D30, D44, SOA
1977 Chevrolet C/10 step side 454 TH400 3.73 posi
titomars is offline
post #28 of 62 Old 04-26-2013, 11:13 AM
Nafpu
2012 KK Liberty
E-brake turns in a CJ?
95 YJ, gone...
80 CJ7, gone...
Nafpu is offline
post #29 of 62 Old 04-26-2013, 11:17 AM Thread Starter
vivimus
I've had this jeep for 10 years, a CJ-5 for a few years before that, and a few cars as well, all manuals, and I rarely parked in gear. Sometimes I did, sometimes I didn't, never mattered so I got complacent. This is the first time an e-brake has given out on me, in any of my vehicles. Needless to say, I learned my lesson and will henceforth be parking in gear.
Originally Posted by sluff28 View Post
if you are getting any voltage (mine was 4v you should think about a starter) I only know as mine just died 2 weeks after getting stranded during a river crossing and that's what I did to get to a starter diagnosis.
Back to the problem at hand. Voltage looked good across the solenoid, but at the cheaper of the 2, we replaced it anyway. Still no dice. The cable from the solenoid to the starter "jumps" when I turn the key (like when electricity is applied to a muscle and it tenses up). Nothing more. It's looking more like the starter and I think I'm about to go pick one up.
vivimus is offline
post #30 of 62 Old 04-26-2013, 11:33 AM
roboto65
1976 CJ5
Ok read this again you said you drained the fluids. Did you Pull the plugs ?? You said it tensed up well if there is water in just one of those cylinders it won't start and if it did well time for a new engine.
roboto65 is offline
